My catch can routing ok?
Old Jul 18, 2012 | 03:43 PM
  #461
NEXRACE's Avatar
Is there any problem with running it this way?
Old Aug 15, 2012 | 02:57 PM
  #462
MillerTime85's Avatar
Anyone off top of your head know what size hose from the passenger side valve cover to throttle body?
Old Aug 15, 2012 | 02:59 PM
  #463
FASTFATBOY's Avatar
3/8 hose
Old Aug 15, 2012 | 03:16 PM
  #464
99Bluz28's Avatar
I don't see any problem running it that way, but it would be easier to just put the PCV closer to the catch-can.
Old Aug 15, 2012 | 04:22 PM
  #465
Arn't there catch cans that have built in pcv's?
Old Aug 20, 2012 | 08:20 PM
  #466
Nasti98Z's Avatar
You speak of not using filters on the catch cans due to un metered air (MAF) metering I assume? what if there is no MAF, speed densety tuned? It should'nt mater then should it?
Old Aug 20, 2012 | 09:55 PM
  #467
Just a question.You can get a dual catch can for both the clean and dirty side PCV but if your running a single can on the dirty side (which is most important) but aren't you still coating your Intake with oil (but nearly as bad) if not running a catch can on clean side as well.Wouldn't it be best to say go with a dual catch can or go home?
Old Aug 23, 2012 | 09:14 PM
  #468
^^^^ Anyone?
Old Aug 23, 2012 | 09:24 PM
  #469
My6speedZ's Avatar
Originally Posted by FASTFATBOY
Someone ID this catch can for me, where did it come from??
Looks like the one I have, Rev extreme or something like that. They have it at WS6store.
EDIT: it's the Norris Motorsport catch can.
Old Aug 24, 2012 | 07:31 AM
  #470
........ Just a question.You can get a dual catch can for both the clean and dirty side PCV but if your running a single can on the dirty side (which is most important) but aren't you still coating your Intake with oil (but nearly as bad) if not running a catch can on clean side as well.Wouldn't it be best to say go with a dual catch can or go home?
Old Aug 24, 2012 | 05:49 PM
  #471
99Bluz28's Avatar
Most, if not all of the oil is from the dirty side. I've never had any oil issues through the clean side, but I do run 2 catch-cans on the dirty side just to keep the oil vapor deposits to a minimum.
Old Aug 24, 2012 | 06:23 PM
  #472
Thats what I would imagine but I read somewhere where someone had a dual catchcan setup up.1 for dirty side and 1 for clean and by the time the dirty side was full he caught like almost 1/4 full on clean side.
Can anyone running that setup chime in?
Old Sep 18, 2012 | 04:20 PM
  #473
Drew-Bot's Avatar
I have a 383 stroker with ls6 intake/tb H/C/I what set up would you guys suggest? Just a standard 1 can set up? It is my DD and i never really go to the track maybe once a year. What size and how much hose would I need?
Old Oct 23, 2012 | 09:59 PM
  #474
idlerelaxation's Avatar
im running the setup shown in the picture but with both passenger side valve cover ports capped off, would it be better to run the front port uncapped until i can get a hose to run from the throttle body to that port?
thanks in advance
Old Feb 7, 2013 | 09:14 PM
  #475
jsmith564's Avatar
I just skimmed threw all 24 pages and tried to make since for my setup but fail to grasp it 100% I know this has been covered 100,000x's, i know! and I'm sorry, but...
i have a 2002 camaro, just want to make sure i get this correct b/c it has a fresh motor collecting oil in the intake manifold. anyway i have a
ls6 valley cover
ls3 intake
my edelbrock TB doesn't have any hose port connections
passenger valve cover has a breather in place of oil fill cap.
drivers VC has no port for hose connection, must have been swapped out during the engine swap.
I have seen many suggestions for good catch cans, now i just need someone to properly spec out weather if I need a single or dual and how to route the hoses. thanks a bunch.
Old Feb 16, 2013 | 03:21 PM
  #476
slow ride 02's Avatar
ls6 valley cover
ls3 intake
I am with you! 24 pages, and I am really confused. Buy a Norris or not?
Old Feb 16, 2013 | 03:24 PM
  #477
jsmith564's Avatar
Im getting oil in my intake... it has 5k miles. I know it needs to break in still. Either way i want one.
Old Feb 16, 2013 | 05:38 PM
  #478
LilJayV10's Avatar
What are you still confused about? Let us know so we can help get things straightened out.
Old Feb 16, 2013 | 05:41 PM
  #479
Buy a NORRIS or not?
Old Feb 16, 2013 | 06:53 PM
  #480
LilJayV10's Avatar
I think the Norris can is the most reasonably priced can. The Rev xtreme and the "Shidokia" can are probably better due to them being a dual can setup but they are more expensive.
