My catch can routing ok?
I ordered the Rx breather, hopefully that will fix it. Why keep the air tube with the breather? I'd think it would be best to get rid of the tube since that's where the oil is coming in at.
I am nearing completion of my build which is the swap over to a stock crate LSx454. I have gone for a Jenvey independent throttle body injection system.
I have drilled and tapped each runner and taken a small vacuum line from each back to a common manifold block behind the engine, this will go off to the brake vacuum booster, I also have spare ports for an oil catch can.
I have purchased a Mishimoto carbon fiber oil catch can but now reading this thread I am unsure if I have done the right thing.
There are vent tubes on each of the rocker covers. there is also a vent tube on the top of the valley cover. I assumed I would connect these three and then take them back to one tube on the top of the can, and the other on the top of the can I would take and plumb into the vacuum block.
But is this correct?
Here is a picture of the bay
These are the vacuum lines I did that go back to a common rectangular manifold.
This is the can
You could probably connect a hose from each valve cover port into the back side of what ever type of air filter assembly you use then any vapors vented will be pulled back through the engine.
That's why I was planning on taking it back to the manifold block, I thought it doesn't matter if they get fed in before the throttle bodies in the air cleaners, or just after in the vacuum tapping I have?
