My catch can routing ok?
I have the closest to this setup
... LS6 valley, but no one seems to mention the connection behind the intake manifold that has the Y connector where the line from the rear of the drivers side valve cover that continues to the pass rear valve cover vent. The second line of the Y goes to the front section of the pass side, the hard plastic tube.
So, what I need to know for my application *Single Norris catch can* is what ones to cap off. And which to run where and where the PCV valve needs to be placed. I do not want to mess anything up so that is why I am asking.
Hopefully I am just making this harder than it needs to be? Is the right answer just cap off both rear valve cover ports and eliminate the Y with the additional line then run from the pass front vent to the TB as pictured and route the others just like in the diagram?
And is the dotted green line to the bellows just an optional location as opposed to the TB?
Thanks in advance for any assistance.
Dave
My cars setup is a forged 427 making 540 rwhp, and I have a problem. There has been at least 1 occurance when I've finished a long hard WOT pull and the oil dipstick was pushed out of the hole and oil spattered everywhere. This leads me to understand that my crankcase is building up too much pressure. I was hoping I could get some advice for changing my setup to alleviate this problem. I was thinking of switching to the second picture provided.
https://ls1tech.com/forums/attachmen...ing-ok-web.jpg
Dave
and by any better i mean 'not at all'
you are giving the blow by nowhere to go but out the main seals and dipstick tube.
with some dual cans or dual exit cans, your can opt to force all of the blow by and crank case pressure directly into the intake air stream. not a very good solution if you ask me.
BTW I'd keep the fresh air tube on it.
