My catch can routing ok?
Old Mar 7, 2009 | 01:01 PM
  #121
panterx1's Avatar
Default Aftermarket valve covers
A ton of info I had been looking for in here.
I am getting ready to install a LS6 valley cover, RevXtreme catch can and some GMPP Valve covers.
I am good with running all the hoses except that the aftermarket valve covers don't have any ports to hook the hose to the TB.
The only thing I could think of is:
1) Blocking off the port on the TB, slap on a breather and not worry about it...but after reading this, that may not be the ideal setup.
2) Drill/tap and add a fitting to the valve cover to install the hose. I need to take a look at the covers to see if i can do that.
3) Maybe add something like the attached picture on top of the valve cover and run a hose to the TB...This might be the easiest.
Any suggestions on what I should do?
Old Mar 7, 2009 | 05:11 PM
  #122
405HP_Z06's Avatar
I would drill and tap the valve cover with 1/4" NPT and use a nice AN -06 to 1/4" NPT 90 degree fitting like this:
and a AN -06 female push lock fitting like this:
Or use AN to AN if you want to use some nice hose. If you use a breather like the one in the above post, make sure it doesn't have a PCV valve inside; Many of these do.
Old Mar 8, 2009 | 03:04 PM
  #123
panterx1's Avatar
Thanks for the help.
Old Apr 17, 2009 | 10:15 AM
  #124
dreamls1's Avatar
Originally Posted by 405HP_Z06
Like this:
I set up my system this same way, getting lots of oil in the down pipe. Should I put a filter on the oil cap?
Old Apr 17, 2009 | 11:02 AM
  #125
405HP_Z06's Avatar
Are you collecting any oil in the catch can? Which can are you running?
Old Apr 17, 2009 | 11:03 AM
  #126
dreamls1's Avatar
I dont think i have any oil in the can. Just an ebay can.
Old Apr 17, 2009 | 11:14 AM
  #127
98Camarod's Avatar
I'd say that's most likely the problem
Old Apr 17, 2009 | 12:33 PM
  #128
dreamls1's Avatar
What the catch can?
Old Apr 17, 2009 | 01:39 PM
  #129
405HP_Z06's Avatar
Try moving the catch can to the clean side and see if this helps the problem. One important aspect of maintaining a sealed PCV system AND minimizing carry over oil ingestion is a quality catch can.
If your eBay can is an empty container with hose ports, its not doing much of anything to reduce the speed of the blow by gases exiting from the crankcase. Forced induction applications are more sensitive to this because of the increased crankcase flow. PCV flow must be below 1 meter/second for as long as possible for carry over oil to separate from the crankcase stream.
Old Apr 17, 2009 | 02:01 PM
  #130
dreamls1's Avatar
How do I route to the clean side? What's a good catch can?
Old Apr 18, 2009 | 11:41 PM
  #131
Sharpe's Avatar
Old Apr 19, 2009 | 07:35 PM
  #132
405HP_Z06's Avatar
Here's a diagram for a clean side catch can only. Concerning a good can, you should really run two cans. For your application, I would recommend a Saikou Michi dual.
Old Apr 19, 2009 | 08:04 PM
  #133
98Camarod's Avatar
Nice diagram, I guess you are getting tired of the questions
Old Apr 19, 2009 | 09:51 PM
  #134
405HP_Z06's Avatar
Yep, I get quite a few questions on this subject.
Old Apr 20, 2009 | 01:17 PM
  #135
dreamls1's Avatar
sorry for the questions, it's a learning process for me. Glad your here to help
Old Apr 20, 2009 | 05:02 PM
  #136
405HP_Z06's Avatar
No problem, keep asking if you still have questions.
Old Apr 21, 2009 | 10:30 PM
  #137
RCowan's Avatar
Question
When you convert an LS1 to the LS6 PCV system, why not connect the back sides of both valve covers together to get fresh air to both sides?
like this...
Old Apr 22, 2009 | 01:25 AM
  #138
LS1nterceptor's Avatar
I've got a question for you.
I am getting a lot of oil through the tube that connects the passenger side valve cover to the throttle body. I believe it's what you refer to as the "clean side". That's where I was planning on putting a catch can. But I noticed that someone else did that and was told that he had it in the wrong location.
In my case, that seems to be where I do need it. Why is that? Why is my clean side pumping oil into my throttle body? And yes, I did double check. There is definitely il coming in the clean side.
Is this normal? Or do I have a problem I am unaware of? The car is running well, I just don't like the mess.
Do I need a catch can on both the clean and dirty side? Or is there another solution?
Old Apr 22, 2009 | 02:19 AM
  #139
KW4life06's Avatar
Very interesting thread. I have a few questions, if thats alright? One is, will the clean side always be the passenger side/dirty side drivers side due to rotation of engine, or is it reversable. Also, I'm running a RevXtreme catch can, and it blocks off the front port on the clean side, but then what is the rear still used for? If the front is closed off, where is it going to pull for the clean side? (ls1)
Old Apr 22, 2009 | 03:51 AM
  #140
KW4life06's Avatar
For any of those interested in the RevXtreme catch can, here's some pics of it installed (with the sticker removed). Also found a sticker in my engine bay I never noticed until the topic.
