Solid Motor Mount "Comfyness"
Old Jan 27, 2009 | 08:43 AM
D_Rock's Avatar
El diablo I was under the impression that if you went with solids they replaced the Motor Plates as well.
Old Jan 27, 2009 | 09:13 AM
1CAMWNDR's Avatar
If you need to remove the trans, loosen the rear 4 k-member bolts=enough droop to get the top trans bolts.
Next ?
Old Jan 27, 2009 | 09:20 AM
D_Rock's Avatar
Dont the solid motor mounts replace the Stock plates and the rubber mounts? Thats why there is so much weight savings in replacing to solid mounts. Now I think if you go Poly then you use the motor plates in conjunction with the poly's is this right?
Old Jan 27, 2009 | 09:26 AM
El_Diablo's Avatar
Yes, the solid mounts do replace all of that heavy stock junk. I believe you are refering to the clamshells when you say motor plates. The motor plates I was refering to are plates that are welded to the body/frame and bolt to the block.
Old Jan 27, 2009 | 09:51 AM
dug's Avatar
dug
Originally Posted by Joshiedoom
"The stock LSX motor mount bushings are located on top of solid cast iron pedestals, they weigh in at 18 pounds/pair. The Spohn tubular motor mounts weigh only 8.5 pounds/pair!"
it all adds up
Old Jan 27, 2009 | 07:21 PM
1999FirehawkLS1's Avatar
I have solid motor mounts in my car and i can't hardly tell theres no exhaust rattle or anything good mod....
Old Feb 10, 2009 | 04:01 AM
metalmechanic's Avatar
i have solids, no regrets
