ported 90,,,, need to make a gasket {need help}
Old Feb 6, 2009 | 09:22 AM
johnster's Avatar
Default ported 90,,,, need to make a gasket {need help}
hey guys i ported out the mouth of my fast 90, well the 0 ring wont work any more, i need some ideas on makeing a gasket 4 it???? thanks john
Old Feb 6, 2009 | 09:35 AM
RZRSEDGE's Avatar
Gasket material and some sensor safe RTV. I think that's what I've seen used before.
Old Feb 6, 2009 | 09:40 AM
shortdog's Avatar
9 Second Club/Nitrous Mod
Get some gasket material from Autozone, Advance Auto Parts, etc. Then, you will need to press the gasket on the manifold to get an "indentation" to cut it. I had to go that route until the o-ring finally came.
Old Feb 6, 2009 | 10:20 AM
johnster's Avatar
thanks guys shortdog did it leak any??
Old Feb 6, 2009 | 01:42 PM
JonCR96Z's Avatar
Yeah the gasket material will work fine. We use to use cereal boxes back in the LT1 days.
Old Feb 6, 2009 | 04:45 PM
SS1875's Avatar
Would the gasket for the 92 work? or did you take out the o-ring groove when porting it? The other posters have some good ideas for making your own gasket, I was just curious as to how far you went with it.
Old Feb 6, 2009 | 06:24 PM
studderin's Avatar
a good tip on the Oring inlets, that you will be removing not fully the Oring groove. is to fill the groove with expoxy before you start the inlet opening work. drill some little 1/16 holes like normal fingers expoy work. than get the inlet new expoy flush (machine it, belt sand, or hand file) with the stock surface.
Doing that after your done with the inlet size, you have max gasket surface. also good on the gen3 75-78 orings setups were the Oring would have gone up over the IAC passage, and you will only have a little 1/16 OD profile for the DIY gasket to seal to. I see about getting some pics later, Ive done that a few times
Old Feb 7, 2009 | 12:21 AM
johnster's Avatar
ya post some pics plz!!!!!
Old Feb 7, 2009 | 07:40 AM
shortdog's Avatar
No leaks, but I went ahead and removed it when my o-ring finally showed up.
Old Feb 7, 2009 | 08:58 AM
LS1Formulation's Avatar
I ported my 78MM FAST to 85MM and when I bought the 85MM TB, it came with a flat rubber gasket and an adapter. Since I wasn't using the adapter, I just used the flat rubber gasket because I ground my TB opening to the outer edge of the o-ring groove. I've had it on for a year and a half now with no issues. My suggestion is to call Byunspeed and see if they can get one of those replacement gaskets for you so you can use it.
Old Feb 7, 2009 | 02:45 PM
500hpZ06's Avatar
What does that Professional Products intake use?
Old Feb 8, 2009 | 10:54 AM
johnster's Avatar
im going to port this thing to 100mm, i no they say it cant be done, ill post pics when im done, the bottom side of the neck is where u run in to trouble, im going to have 2 expoxy it.
