Catted Y for Hooker Headers
Old Oct 12, 2003 | 11:43 AM
onebadz's Avatar
Default Catted Y for Hooker Headers
Hey guys the only one I have been able to find is QTP's and its 500 bux. Do yall know of any other catted Y's for hookers. Thanks for the info.
WeS
Old Oct 12, 2003 | 11:53 AM
Jeffs99SS's Avatar
Default Re: Catted Y for Hooker Headers
The only 2 I have seen are from QTP (which you already know) and Jet-Hot. You might try and some pictures first, because they don't use conventional cats, so dependig on your smog laws may not work.
Old Oct 12, 2003 | 10:29 PM
jrp's Avatar
jrp
SN95 Director
just go custom, mine is. i got carsound cats.
Old Oct 12, 2003 | 11:15 PM
onebadz's Avatar
If you go custom and buy an ORP do you put the CATS onto the collectors.
Old Oct 12, 2003 | 11:50 PM
blk~2000~Z28's Avatar
If you buy the ORY you need only to cut out sections to fit the cats into. Then weld the cats to the y-pipe. That is probably the easiest way to do it.
Old Oct 12, 2003 | 11:53 PM
onebadz's Avatar
Ok thanks man i will sure do this, can i buy just any CAT out there or is there any ones that stand out.
Old Oct 13, 2003 | 10:53 AM
gymratt's Avatar
Carsound seem to be the most popular and highest flowing. I remember reading there were some durability issues with the carsounds failing after a couple years or less for some owners, while others had no issues. Try a search on carsounds
Old Oct 13, 2003 | 08:41 PM
onebadz's Avatar
Can I reuse the stock O2s or do i need o2 extensions or what?
Old Oct 15, 2003 | 08:08 PM
onebadz's Avatar
TTT
Old Oct 16, 2003 | 01:37 AM
Jeffs99SS's Avatar
Not sure about the hookers, but i think you will need O2 extensions for the front O2's. If you run cats, I believe you can run stock O2's in the rear. I you go ORY, you will need to get some sims
