LS2 Intake on 346ci ANYONE tried this!!!
I would say that fuel rail hooks up the same i duno havn't got one yet it sounds cheaper to buy katech's spacer and go with your ls1 rail so ya dont have to buy the ls2 harness for 100 and buy a ls2 fuel rail unless ya already got one....the ls2 runners on the intake are taller thats why ya need the ls2 rail or space them or ive herd of ppl bending there ls1 rail and getting it to work but if you bent it wouldn't ya think it would draw the rails closer to each other when ya think about it
ya its alot of diff stuff to make it work but if it makes me as much power as a fast if i get it port epoxy and i only got 400 in all of that im ahead of the game......going to have to buy a 90mm tb anyways with ls2 or a fast
do you think my ls1 injectors will work in the ls2 intake. they seem to fit okay but i won't know untill I put it on the car to see if it leaks fuel or air. Can they be refitted with new o rings
have u put the tintake on the car yet w a tb and have u had any problem w the tb hitting the water pump (assuming your putting this on your ls1 motor)
pics would be nice!!!
#33
Moderator
I'm not arguing this, only posting info. Check out this link and read graph #4, the LS2 intake vs LS6 intake on an LS2 engine.
http://www.vetteweb.com/tech/vemp_06...o_testing.html
#34
4.maf wire extender $25 (cause the maf is in the front instead of the back)
http://store.katechengines.com/share...ount2=33332467
scroll down and click on conver and swaps
were can u buy the manifold that u eliminate the maf its not the fast
why would you wanna eliminate the maf? and you could plug the hole if you wanted to ditch it i guess
#36
#37
#38
you can get a fast 90 for around 500 used. A lot less hassle. Plus after you buy the intake and the little stuff you need for the swap, get it ported etc., your going to be spending about the same.
#39
and herd that fast can burn up #7 cyc
ls2 intake $100 new
Port work $275
Holley 90mm TB w cable hold brackets 379.00 (going to have to buy 90mm tb no matter what...)
swap stuff to make it work $50 w useing fuel rail spacer
going to have to buy injectors no matter what...
$425 total
#40
you dont have to buy injectors with a fast. I got mine with a throttle body for 750 on the classifieds here. I think your math is a little off too, 50 bucks for everything to do the swap? One of pieces you listed was 70 by itself.
