Throttle Body sticking
Old Feb 28, 2009 | 05:03 PM
SLP LS1's Avatar
Default Throttle Body sticking
When I punched it the other day on the highway, I noticed the throttle seems to be sticking. I popped open the hood and noticed the throttle body wasn't going back to the normal position. I pulled it back to it's normal position. I tested the throttle wire to see if it was sticking at all, it wasn't. So I think it's the spring in the TB, may be worn out and not putting enough tension on the wire to go back to it's normal position. Or the plates may be sticking inside.
I currently have a MTI aftermarket TB, so I ordered a stock LS1 tb on GM Parts direct.
Has anyone had this happen to them before to there tb, whether it's aftermarket or stock?
Old Feb 28, 2009 | 05:45 PM
nemss1's Avatar
butterfly may be catching on the inside of the TB bore
Old Feb 28, 2009 | 09:28 PM
dadowd's Avatar
this is a common problem in the ls engines. the fix i was told at the dealer is to loosen the 2 bolts that hold the butterfly in with the throttle closed and then re-tighten them. all 5 of my gm vehicles have had the problem and their solution fixed it.
Old Feb 28, 2009 | 09:30 PM
02BLKWS6MD's Avatar
Have you tried cleaning it? Maybe its got some carbon buildup on it. BTW love the sig, The Wraith was the ****.
Old Feb 28, 2009 | 10:14 PM
nemss1's Avatar
^^^true also. our TBs get alot of gunk around and behind the butterfly that may also cause binding
Old Feb 28, 2009 | 10:37 PM
thunderstruck507's Avatar
pull it off and clean it with brake parts cleaner and scotchbrite if it still sticks hit the area where the blade seals with a couple passes of sandpaper at a time until it stops
Old Feb 28, 2009 | 10:57 PM
Swift_01_z-28's Avatar
Mine has started doing this since I got my stock tb ported and polished. It only sticks right at first, but once I have pushed the pedal in once to unstick it, it doesn't do it again until I let the car sit for a few minutes. I have unscrewed and rescrewed the screws on the butterfly, but it is still doing this.
Old Mar 1, 2009 | 01:17 AM
quikrnmost's Avatar
No doubt it's the blade. Take the blade out and clean the TB. Then adjust the blade so it doesn't stick.
Old Mar 1, 2009 | 09:26 PM
SLP LS1's Avatar
wish I would of read this before I went out and bought a stock TB, see this is an MTI aftermarket, so I don't see why it would stick. I'll take it out the next day and try to clean it. I guess it's good to have the stock tb anyways, just in case.
