ARH headers question
Old Mar 4, 2009 | 11:04 PM
69COPO's Avatar
Default ARH headers question
does anyone know what i would need to do to install 98-99 american racing LT headers and y-pipe on a 2000 z28, or will they work fine. any help appreciated, thanks.
Old Mar 4, 2009 | 11:08 PM
99blancoSS's Avatar
air tubes will be located differently IIRC
Old Mar 4, 2009 | 11:47 PM
69COPO's Avatar
so can i make them work? or is it not worth it.
Old Mar 5, 2009 | 08:20 AM
ramairJP's Avatar
Delete the AIR and EGR and put block off plates on the headers and it'll work just fine.
Old Mar 5, 2009 | 06:57 PM
toothdoc's Avatar
I wouldn't block off the AIR and EGR. I was told specifically by ARH not to do it because too many people that do it blow holes in their headers. I would either get the right headers for your car or get the proper AIR tubes from someone that has a 98/99 car. If you are going to spend that kind of $, you don't want to end up with a hole in them.
Old Mar 5, 2009 | 07:25 PM
99blancoSS's Avatar
Good point/idea, the plates put extra weight on the un-supported tube as well. It vibrates back and forth and tears at the metal in front of the weld.
Old Mar 5, 2009 | 08:48 PM
jmilz28's Avatar
Race headers and tune FTMFW.
Old Mar 5, 2009 | 10:29 PM
69COPO's Avatar
i just talked to ARH today and they told me not to run the block off plate too. i need to keep the egr for emissions anyways, i also talked to a performance shop and they told me they could relocate the egr on the headers. has anyone done this before?
Old Mar 6, 2009 | 12:53 PM
PAGregSS's Avatar
Buy the headers and find someone that can weld stainless. Cut off the air and egr tubes and weld up the holes. If it's a good deal for the headers, the few bucks spent to remove the air and egr will be worth it. Plus, it's a heck of a lot easier to work in the engine bay without them in the way.
