witch head is better?
Old Mar 4, 2009 | 11:19 PM
LSXFORMULA99's Avatar
Default witch head is better?
how much hp gain do u think i would get going from a stock 241 head to a stock 243 head?
i have noticed u can get a used set of 243 ls6 heads for a decent price. just dont no if it would even be worth it. does anyone know what the differences are.
Thanks
Old Mar 5, 2009 | 07:50 AM
teke184's Avatar
with a mild cam....10-20hp is easily possible
while you're swapping them, spend a small amount and have them milled...boost compression for more power
Old Mar 5, 2009 | 08:17 AM
EVIL z28's Avatar
The 243's have a 64 cc combustion chamber and the 241's have a 66.67 cc combustion chamber. The 243's also have a D shaped exhaust port and flow a little better. Do like teke184 said and get them milled for even more compression.
Old Mar 5, 2009 | 12:31 PM
ok thanks guys. so u think they are worth 500 or so.
if i mill them a little would that put me around the race gas compression zone.
Old Mar 5, 2009 | 01:03 PM
teke184's Avatar
not sure they are worth $500 unless they come with good springs already.
that's alot for a stock head.
ported heads are only about 2x that, and they'll flow much better.
you can run 11:1 or higher and still use 93. you shuold be fine.
Old Mar 5, 2009 | 02:36 PM
edzsilverss's Avatar
How about going from 853's to the 243's. The 853's are the worst flowing of them all correct?
Old Mar 5, 2009 | 04:04 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
HMM maybe ported heads are only a little more than that.
GTP241S1
they are ported, 241s, stainless valves, LS6 springs. Very good bolt on head. $800 Shipped for the set
Old Mar 5, 2009 | 05:21 PM
EVIL z28's Avatar
853's flow the same as 241's. 243's would be better than 853's.
Old Mar 6, 2009 | 03:02 AM
i thought the 241s were better than the 853. but im still looking for a set of 243s for my car.
Old Mar 6, 2009 | 03:04 AM
GTP241S1
that is a good price for them. i wander what they are like.. does anyone have these heads
