Thanks Patrick G Nice Gain with Flowmaster Merger Y Pipe.
Old 03-19-2009, 10:22 AM
  #61
titter's Avatar
Originally Posted by TORCHD 02 TA
you did not gain that much just from a merge. Not possible. Unless you dynoes your car b4 and after.
Sorry bud, your strectching it a little to far
He didn't gain that just from a merge, he gained that from the merge, and I-pipe together. Having a 4" I-pipe greatly increases exhaust flow, and will allow maximum power for a Y-pipe. Someone posted the correct math before, but I will explain it a little more.
You have to think about two 3" pipes merging into each other. The combined area of two 3" pipes from your Y-pipe would be 14.13 square inches. If you have a 3" I-pipe, you have an area of 7.065 square inches. Which now means you are dumping a combined 3" Y-pipe into 7 square inches, or basically halving the output. If you were to merge into a 4" I-pipe, the 4" I-pipe has a area of 12.56 square inches. The 4" pipe has 43% more area than the 3" pipe. It also almost matches the output of two 3" pipes, which will greatly increase exhaust flow. Also just for reference, a 3.5" I-pipe would only have an area of 9.6163 square inches. The 4" pipe still has 23% more area.
If you want to check the math, Area of a Circle, A = Pi * r * r. In this case, we are dealing with diameter, so you would first convert diameter to radius ... d / 2 = r.
Old 03-19-2009, 11:09 AM
  #62
TORCHD 02 TA's Avatar
where can you get a 4" I pipe from?
Old 03-19-2009, 11:30 AM
  #63
Mumbles's Avatar
Originally Posted by Black Sunshine/ 00SS
I have the same Spohn TQ. It will fit in there, I have the 3 in 4 out setup, and it fit, barely. You have to put the merge in there, and then cut accordingly. I'm not sure how far your Y goes back into the loop.
I had a custom piece done, that looks like ****, so I'm about to do it with the Eldebrock Y. Plan is to cut that Y right where it merges, place the Flowmaster Y where it fits best, and then cut pieces to bridge the gap. I'll post up pics when I'm done.
Yeah some pics would be great. Thanks for the info...
Old 03-19-2009, 11:33 AM
  #64
Pontiacerator
RevGTO's Avatar
Everything you say is true, but you also need to take into account the output of the motor to determine the most effective pipe size. Piping that is too big will cause loss of exhaust heat and velocity. Too much pipe for too little motor doesn't gain anything.
Old 03-19-2009, 11:57 AM
  #65
titter's Avatar
Oh I agree. It just seems this setup works well for mild to highly modded LS1's. Let me rephrase, it is the best y-pipe setup I have seen on any modded LS1's to date.
Old 03-19-2009, 12:01 PM
  #66
titter's Avatar
Make one. Look at Pat G's pictures on this page:
http://guerragroup.com/2000TA.htm
It is nothing more than a pipe that goes from the collector to the catback. The correct term is intermediate pipe, but I just say I-pipe for short. If you have the proper merge collector, it would be an easy swap, then just reduce it back down to 3" or whatever your catback size is.
Old 03-19-2009, 12:58 PM
  #67
well i want to gain 10 RWTQ.. I already have a flowmaster merge
Do you think that a 4" I pipe would be to much for my application? I do have a cam stock H/I
Here is my exhasut set up....
QTP LTs (1 3/4") + Kooks O/R Y Pipe (3'') + Flowmaster Merge (3" - 3.5") + GMMG c/b (I pipe is 3" and it necks down to 2 3/4")
Old 03-19-2009, 02:18 PM
  #68
ls2 bait's Avatar
that cdid not gain 10 rwhp with a merge and 4" i pipe. sorry. ive had that set up....i dont anymore.
Old 03-19-2009, 03:43 PM
  #69
I new it was not possible, i think with such a big diameter, you would lose HP?
Old 03-19-2009, 06:23 PM
  #70
Ping King's Avatar
Swapping the merge made the farm truck sound go away.
Old 03-20-2009, 02:27 PM
  #71
ls2 bait's Avatar
i doubt it lost but it certainly didnt do the big gains he thinks it did.
Old 03-20-2009, 02:43 PM
  #72
corvet786c's Avatar
Man I didnt think my post would go this long?
Old 04-27-2009, 01:52 PM
  #73
loyolacub68's Avatar
What size merge would be good to go with if you wanted to keep your stock exhaust manifolds? I want to stay emissions legal for California.
Old 03-16-2010, 07:43 PM
  #74
pitbull14218's Avatar
bump, so thinking of doing this, my car has a bad exhaust leak and a beat up y pipe
Old 03-17-2010, 10:44 AM
  #75
green28's Avatar
Well since this got bumped up, I was wondering how much this costs for an exhaust shop to do. I can figure on around $50 for the flowmaster merger and I already have a pacesetter ORY on the car, so what would it cost to have them chop it up and put it back together with the flowmaster merger and a bigger i-pipe?
Old 03-17-2010, 01:06 PM
  #76
KurtRardin's Avatar
I think it cost me ~$120 to have them weld in my V band clamps that I brought to them, and weld/fab in the flowmaster merge, which I got from them. They had some pre-made mandrel bends on their shelves so I didn't end up with any crush/wrinkle bent stuff.
I'd figure less than a hundred, for sure. But it better have mandrel bends for that kinda money.
Old 04-03-2010, 02:15 PM
  #77
corvet786c's Avatar
The Merger is not perpindicular, but merges the scavenging gases properly with no obstruction.
Old 04-04-2010, 01:13 PM
  #78
chrs1313's Avatar
we will see what my 3" to 4" flowmaster merge does...my y pipe looks worse than the one partick g posted...i will take some pictures tomorrow...looks to be bent over a knee...
i will have dyno results sometime soon maybe 3-4 weeks...shooting for around a 5rwhp gain...plus i am going to make it out of aluminum to drop some weight too...about 10lbs vs steel...
Old 04-09-2010, 02:21 PM
  #79
ICRAZY6's Avatar
I'd like to see some pictures of your y-pipe with flowmaster merge. I just ordered one and need to get my exhaust to tuck up closer to the body. I currently have a TSP Y-Pipe but I'm also lowered on Strano's so clearence is an issue.
Old 04-09-2010, 08:36 PM
  #80
KurtRardin's Avatar
Here's a pic of my 4" flowmaster merge fabbed into a pacesetter Y pipe:
and here's a bad picture of the ground clearance (stock ride height):
...and one under the merge:
...and one last one to show how decent the clearance can be on the drivers side. If I had only let the guys know that I had poly mounts then they probably would have tucked it up even higher (they must have run into some problems in the past with customers who insisted on clearance and stock engine mounts...).
Not the prettiest thing, but it works quite well!
Quick Reply: Thanks Patrick G Nice Gain with Flowmaster Merger Y Pipe.
