View Poll Results: Need to know which header makes more HP w H/C
Hooker Super Competition Headers LT
8
53.33%
Pacesetter LT
7
46.67%
Voters: 15. You may not vote on this poll
Header for the most Power?...
Old Mar 23, 2009 | 08:14 PM
1999FirehawkLS1's Avatar
Default Header for the most Power?...
Basicly i wanna go with the Header with the most power and trying to get around the 480HP mark with them.... with afr's and cam on stock bottom end.
I think i only have these 2 options as of right now and if thats the case when the time comes i need to know
thx
Old Mar 23, 2009 | 08:32 PM
blown03mustang's Avatar
hmm id say theyd both be about even. if it were me id go with a stainless headers. i personally went with QTP and picked up quite a bit over my SLPs! the owner of the local ls1 shop swears by pacesetters and puts them on most ls1's that come through wanting headers. so far of the ones ive seen theyve made very decent power, but the only downside being they rust after while
Old Mar 23, 2009 | 08:54 PM
Were these the same size primarys?
Old Mar 23, 2009 | 09:57 PM
nalmak's Avatar
Agreed..Pacesetter's and Hooker's will rust after a while..Longevity, go with A stainless steel one Kooks, QTP, ARH..But bang for buck is Hooker and Pacesetter
Old Mar 23, 2009 | 10:19 PM
yes both 1 3/4 primaries. no mod changes other than exhaust and rear/gears and i picked up power. especially under the curve power! the biggest advice i can give you is dont buy a header based on power alone, they are all within a few hp of each other, but pick your header on quality of materials as well. buy something that will last and wont have to be swapped out down the road. just my .02
Old Mar 23, 2009 | 10:21 PM
sidewayz28's Avatar
ive had pacesetters for 2 years, the car was daily driven in seattle where it rains non stop.... and there not rusted
How close to the steering shaft is your #1 primary?
Old Mar 23, 2009 | 10:33 PM
shiv15's Avatar
Another stainless header not mentioned is LPP. $500 shipped 1 3/4" primary
Old Mar 23, 2009 | 10:35 PM
Well heres what happened my TSP 1 7/8 hit the steering shaft and if its the header they will send me a new one if its something w my car im going to have to try another set i really want the bigger primarys tho..
Old Mar 23, 2009 | 10:39 PM
im not sure but i know there is no tapping or rubbing at all. i also havent changed my motor mounts either
Old Mar 23, 2009 | 10:47 PM
well i have since went back to stock w poly inserts and still haven trouble
Which header makes more power qtp or kooks?
TSP only sells kooks thow
Old Mar 23, 2009 | 10:58 PM
id say they are pretty close, maybe 1 to 2 hp difference at most! i vote for QTPs, but maybe im biased cuz mine have been good to me so far
Old Mar 24, 2009 | 03:24 PM
How much more power will i make doing H/C buying the Kooks 1 7/8 stepped to 2in w 3.5in collector and 3.5in ORY over using pacesetters?
Old Mar 24, 2009 | 04:10 PM
thats way too big, you would want the 1 3/4 stepped to 1 7/8 for stock cubes
Old Mar 25, 2009 | 03:45 AM
RiceEaterZ's Avatar
i've had hooker super comp LT's for a while in a really humid climate and no rust, But hey, they're coated
Old Mar 25, 2009 | 05:21 AM
hitmanws6's Avatar
power with longtubes is about the same regardless of brand as long as the diameter is the same. they are all designed very similarly. the difference would be no more than 5 hp between brands, so just pay for longevity. pacesetter lt's with a jet hot coating will last
Old Mar 26, 2009 | 05:21 PM
Blk_Ws6's Avatar
Cam- 25-80 rwhp depends on the cam.
Heads ls6 on up will be like 15-50 depends on the style.
kook headers will act at its best with the h/c pkg which will be like 20-24 tuned.
Old Mar 26, 2009 | 10:18 PM
TXZ28LS1's Avatar
ive had both hooker headers and pacesetters and both definitely gave big sotp gains. but as far as quality, i did like the pacesetters a little bit better than the hookers.
