interference in headers - how can I tweak them to fit?
I'm doing a second gen trans am ls1 conversion and I got a set of 4th gen headers cheap. They almost fit except for the collectors. The pictures show the dilemma. The drivers side angle is obviously not good and it impacts about 1/4 inch. The passengers side angle is fine, but impacts maybe 1/8 inch.
Should I just bolt them to the engine and try cold bending them in place? If so, what's the best way to go about it?
Or should I just cut the dirvers side collector right after the O2 bung and weld a mandrel bend that fixes both the angle and the interference and notch the frame slightly?
Note: these pictures are of my engine test-fit into the frame rails. The mounts are installed. I wish I had pictures of the engine placed perfectly, but the engine is actually sitting a tad bit too far towards the drivers side - which is why the passengers side collector seems to barely fit, when really it interferes about 1/8in. It's obviously sitting a bit too high as well...
Or better yet, just get some headers that fit, that is what I would do.
I got these headers for about $100. If I can make them fit for < $150 in labor and a one $20 mandrel bend, then I will have spent far less than any header "that fits." In fact, throw in a pair of 3in-2.5in header adapters, a universal x-pipe kit and two mufflers, and I've got an entire exhaust system cheaper than a pair of headers "that fit."
As far as banging, the engine torques down toward the drivers side, right? So if I cut the collector right behind the O2 bung and welded a 20deg or so mandrel bend there, I'd have quite a bit of clearance - probably 1/2 - 3/4in I think. If I can "tweak" 1/2in out of the passengers side, I'd be good to go there. I think the primaries have maybe 1/4in of clearance. I wouldn't be terribly opposed to heating up the offending one a tad and pushing it over. or "persuading" it with a socket and a BFH. I might also be able to move the engine back a bit.
for shims. Loosen all the joints in the exhaust but
just enough for wiggle room. Use a crowbar to
jack the exhaust away from close points and get
the shims in there so you have guaranteed clearance.
Then put the floor jack to the lowest point, get it
to lift the body and go tighten up all the clamps.
You may want to hose-clamp a piece of heater
hose (clamp band inside hose) to where the most-
outboard passenger's side pipe runs closest to the
floorboard.
if the headers are a real mis-fit, and not just a poor
design / tolerance, you may have large problems.
But this is what I had to do on my exhaust to get
it to not bang etc.
cost: $140 for labor, $7 for flanges
Now I just need to get the rest of the project put together, then i can bead blast and send them off for ceramic coating.
check it out if you wish.
