TSP true duel qeustion
Old Apr 23, 2009 | 08:42 PM
97ta383's Avatar
Default TSP true duel qeustion
Has anyone run pipes off the tsp duel set up to the back of the car with tips like under the axel i wanted to get a true duel set up but i have a trans am and it would look dum without any tips just wondering if anyone has done this before
Old Apr 23, 2009 | 08:44 PM
kdick91's Avatar
If you haven't bought the TSP kit yet, you can always get the Bassani TD kit, lucks amazing.
I have seen the TSP kit done out the back OVER the axle, but it was once and I don't remember where I saw it.
Old Apr 23, 2009 | 08:51 PM
deelong4002's Avatar
yeah trans ams dont look good without tips. My camaro on the other hand 100% improvement i think without tips. The only answer to this question is: sell your trans am, and buy a camaro
Old Apr 23, 2009 | 08:54 PM
97ta383's Avatar
^^ lol the bassini exhaust is way to expensive and i would have to cut it up to get it to fit my headers
Old Apr 23, 2009 | 09:08 PM
kdick91's Avatar
I found the Bassani kit for 1000, which you're right it is too expensive, but you said a shop quoted you 1400...
So it is the lesser of two evils.
Hope this helps!
Old Apr 23, 2009 | 09:19 PM
97ta383's Avatar
Hope this helps!
I never got any quotes yet
Old Apr 23, 2009 | 10:59 PM
twitchtwice's Avatar
most logical solution
Old Apr 23, 2009 | 11:40 PM
SS4Luck's Avatar
i have pacesetters to TSP duals under the axle out the rear on my SS. Its all 3" and the tips are in the center kinda like my own CME
Old Apr 24, 2009 | 01:21 AM
97ta383's Avatar
Do you have any pics i would love to see that
Old Apr 24, 2009 | 09:45 AM
greatskiiiier's Avatar
ss4luck's pics will tell you the truth, but i would never run an exhaust under the axle, its wayyy too little ground clearance
i can almost guarantee an exhaust leak, at the lowest point, within the first 150 speed bumps you go over
Old Apr 24, 2009 | 11:21 AM
SS4Luck's Avatar
Ask and you shall recieve
the lowest part of the exhaust is actually directly in line with the tires, so any speed bumps or bumps of any kind the pipes get lifted by the tires. ive had it for 6 months (~2,500 miles) and the only reason i had an exhaust leak was because i accidently jacked the car up without removing the back half of the exhaust and the axle knocked 2 bolts loose
