Happy with your FAST intake?
i'm VERY happy with my FAST. all my gains were on stock heads, which really make me wonder what it would have done on good heads.
mind you this was a home ported intake, just what i could reach with a dremel...did not seperate the intake
my gains:
- 18hp, 12ftlbs peak
- 5-10hp and ftlbs from 3000rpm and up...NO LOSS in the bottom end
- moved peak torque LOWER in the rpm band by 500rpm
- hp still peaked at 6300rpm
thread in the dyno section
the only downside i can come up with was that now it has a wierd hollow, sucking sound to it.
sounds like a vacuum leak, but its not. i hear its normal with the material used on the intake, and the bigger plenum vol of the intake.
my gains:
and as the thread stated....my gains were same day, same dyno, tuned before and after.
as apples to apples as you can get.
Ive been running a 196/200 @ .050 .469/.479 lift cam, I didn't even know they made a cam with under .500 lift on LS engines?!?!?! Anyways, despite my engines short comings, stock intake, stock exhaust manifolds, and puny cam, the FAST intake really made a huge power gains for me.
Again, my dyno graph is done on the dame dyno, same day, same hour, same tune, same 90mm DBW throttle body. I literally just swapped the intake and ran it again so there is no dyno BS!
Its a good intake, but it doesn't require ANYONE to upgrade their injectors. Their injectors would have to too small already and the FAST would just make the situation worse.
i'm still running my stockers...althought hey ARE pretty much maxed out. when i put the heads on (someday) i've got a set of 42# green tops waiting.
How do you measure how much of a fuel injector's capacity is being used?
And like others said, I know for a fact you can get them for way under $1100....
