question about difference between fast 92mm and fast 90mm?
that is if i port the throttle body inlet in the 90mm Fast to 92mm it will be just a 92mm Fast intake exactly?
thanks for help.
and so is for the 90mm Fast if i port it to 92mm it will be just like the 92mm Fast, correct?
i think i will try to open my 90mm Fast to 95mm or even 100mm if the throttle body and a 100mm MAF will fit under my car's hood.
7rwhp/13rwtq over ported 92mm Fast, i don't know if this is the farthest you can go with the 92mm Fast.
i asked a tech @ Fast company and he told me that every thing between the 90mm Fast and 92mm Fast are exactly the same for ports shape and volume and inner parts and design except for the TB inlet which is 90mm for one and 92mm for the other that is if i open the 90mm Fast to 92mm it will exactly the same or it will performa exactly the same as 92mm Fast.
92mm Fast from Vengeance instead of missing with replacing parts from the 90mm Fast.
what size your Fast is? is it 90mm or 92mm? is it ported or not? and by who?
