oil stick removal for headers?
Old Jul 7, 2009 | 10:04 PM
OneSlowCamaro's Avatar
Default oil stick removal for headers?
how do you remove the oil stick? I'm installing some longtubes and all the guides say to remove the oil stick, but I've removed that 15mm bolt and i can't find anything else to unscrew and it won't budge.
Thanks for any help
Old Jul 7, 2009 | 10:11 PM
conan's Avatar
It's just the one bolt in the block and pull straight up. There is a O ring on the bottom of the pipe in the block.
Old Jul 7, 2009 | 10:14 PM
z24turbo93's Avatar
I think my Dad pried it up with a screwdriver while I pulled up and wiggled at the same time.
You already removed the only bolt so it should come out...
Old Jul 7, 2009 | 10:40 PM
I feel like i'm tugging on that thing pretty hard without it giving at all though...
edit: i'm pulling as hard as i can and its not budging
Old Jul 7, 2009 | 11:35 PM
blackws6ta's Avatar
Dont pull straight up on the stick. Kind of wiggle it in a circle and the give a slight tug up. You need to break loose the connection that "O" ring has. If you pull on it, all it is going to want to do is roll that o ring up and make it tighter. move in circles and slight pull up move in circles and slight pull up. You will see that the circles you are making are getting bigger as the tube moves up. Do not go ape SHAT and bend the tube all up and break it off just go nice and easy and it will pull right out.
Mike
Old Jul 7, 2009 | 11:54 PM
Thanks. My hands are actually bleeding from pulling on that thing so hard. But that sounds like a much more effective strategy, I'm gonna give it a try in the morning
Old Jul 8, 2009 | 01:48 AM
Duffster's Avatar
like a 15mm bolt. . . then you ROTATE the dipstick and pull at same time. . .
Conan. . . wrong hole for the bolt. . .it's up by the headers higher and centered.
Old Jul 8, 2009 | 06:08 AM
schuby87's Avatar
The same thing happened to me during my header install. I was under the car with vice grips twisting and pushing while someone pulled from the top and it didn't budge. Put a lot of PB Blaster where the tube goes in to the block. After I did that, I pulled it out from the top with just my hands.
Old Jul 8, 2009 | 06:23 AM
deelong4002's Avatar
Wiggle and pull as hard as you can. You think its hard to get out? Wait till you have to put it back in!
Old Jul 8, 2009 | 09:15 AM
00 Trans Ram's Avatar
Originally Posted by deelong4002
wiggle and pull as hard as you can. You think its hard to get out? Wait till you have to put it back in!
twss!
Old Jul 8, 2009 | 03:11 PM
20Formula01's Avatar
Not tryin to be a douche but I feel sorry for you mine poped right out. The hard part was finding the hole to put it back in cause it was gettin dark out and we were workin with flashlights and a big halogen light.
Good luck!
Old Jul 8, 2009 | 04:38 PM
dlandsvZ28's Avatar
Thanks for any help
Be extra careful to NOT bend the bracket that holds the tube to the head with the 15 mm bolt. If it gets bent in the wrong direction it will not permit the tube to go all the way into the hole leaving the tube partially out of the hole allowing oil out of the hole - it makes a mess in hurry.
In other words - the bracket lines up with the hole for the bolt. If the bracket isn't in the correct position the tube will be out of position as well.
Also - if the tube isn't pressed completely into the hole you will get a false reading on the dipstick showing less oil in the pan than the actual amount. The reason is because the bracket is bent.
Old Jul 8, 2009 | 06:27 PM
well, my bracket wasn't in exactly the right position but i managed to screw it back in... I'm pretty sure i got it all the way back into the hole but now i'm going to double check. I know its not exactly right because there was a lot more resistance than normal when i put the dipstick back in, but it did go in all the way. So far that oil stick was the biggest PITA of the entire install of these headers... but I haven't tried putting in the drivers side yet, so we'll see how that goes.
Old Jul 8, 2009 | 06:49 PM
dlandsvZ28's Avatar
If the oil level is topped off by quarts added before and now the reading is showing low - the bracket is out of position or tube in not all of the way in the hole.
Looking up from the bottom you can see if the tube is seated completely in the hole.
