LS6 vs BBK intake?
Old Jul 18, 2009 | 08:01 PM
Arc00TA's Avatar
Default LS6 vs BBK intake?
I am getting a BBK SSI intake from a member on here, I have an LS6 intake on the car now but its ugly as sin, someone tried to cut an EGR hole in it and failed miserably, so now I have this big epoxy and RTV mess on there to plug up the hole (couldn't beat the price though). My question is, will it make the same power? More or less? Its going on the car regardless I'm just curious. My mods:
03 LS6 stock longblock
224/224 cam
Pacesetter LT's
Port and polish MAF and TB
I am thinking it will stay about the same amount of power, any opinions?
EDIT: I had done a search but all I see is for stock LS1 motors and I'm making a bit more than that.
Old Jul 18, 2009 | 09:26 PM
Blk_Ws6's Avatar
My honest opinion plastic vs. metal under the hood plastic will win all day it won't hold alot of heat.
Old Jul 18, 2009 | 09:36 PM
RS_SS69's Avatar
Had a BBK it holds ALOT of heat in, 4 hours after I shut my car off it was still hot to the touch. LS6 cold to the touch all day long.
Old Jul 18, 2009 | 09:48 PM
Arc00TA's Avatar
Yeah, I noticed about the heat when it was on his car. I'm not too worried about that. I just want to know if I'm going to be sacrificing a bunch of power putting it on the car. Its going on more for the bling factor at this point.
Old Jul 18, 2009 | 10:24 PM
99Ls1fever's Avatar
What size throttle body are you running on the BBK 85mm 80mm? I think it would be a min gain of maybe 5 hp. I like the LS6's!!!
Old Jul 19, 2009 | 12:22 AM
Arc00TA's Avatar
Right now a stock TB, I will probably upgrade to the biggest one I can fit. Later on I will be going FI so I wanted an aluminum one while I have the chance at a killer price.
Old Jul 19, 2009 | 01:35 AM
RS_SS69's Avatar
Well if you went FI and had Meth then it would be fine with the heatsoak or lack there of, but i didnt notice any gain with a ported BBK and 80mm BBK tbody over my ls6, so I went back to the good ol plastic. LS6 are very proven with high hp I would just stick with that. JMO
Old Jul 19, 2009 | 01:59 AM
Arc00TA's Avatar
I got the BBK for half what a used LS6 intake runs. I am going to use it, because I like the way it looks better. You said you didn't notice a gain, but no loss either? I don't mind if I don't gain anything I just don't want to be backtracking.
Old Jul 19, 2009 | 08:12 AM
ja_engineer's Avatar
Are you planning on selling your LS6? If so please PM.
Old Jul 19, 2009 | 08:58 AM
khaotic's Avatar
Default Intake testing
This weekend must be the main dicussion on which intake many posted questions about them here is a like which includes the Weind intake whick is like the
bbk
http://www.tpis.com/index.php?module=2_17_06
I would stay with the Ls6 intake with your setup, yesterday I was testing the Ls6 and the fast 78mm and the weind/Lingenfellter intake using a 78mm throttle body on a stock bottome end long tubes and a 228 228 cam and had better results with the Ls6 intake with that setup in rpm range of the cam.
Old Jul 19, 2009 | 11:14 AM
99Ls1fever's Avatar
There has to be like 7 votes to stay with the LS6! BBK<LS6. Dont waste your time with it. Sell the BBK on ebay and get more for it, since you got it so cheap. RSSS69 Knows his ****, I would listen to him and us others. RSSS69 probabley has been in on over a 100 LSx and LTX Engine Builds since I have known him. Smart Guy!!!
Old Jul 19, 2009 | 11:36 AM
4150's Avatar
bbk
I wouldnt even compare the Weiand/Holley/Lingenfelter to the BBK intake, about the only thing these two intakes really have in common is the material they are made out of.
Other than everyone stating that the BBK will retain heat(which the OP knows already and didnt ask about) can anyone give him a real answer?
Will he lose power over the LS6?
I really dont think he will, from what I have researched on the intake he will either make the same power or gain a tiny amount.
Old Jul 19, 2009 | 11:52 AM
99Ls1fever's Avatar
I Vote he will Stay the same or lose power. Once the engine get hot he is screwed! Espically Since he lives in San Diego. 100 Degrees there all the time
4150- I went through your F quick, Very Beautiful F Body!!!
Old Jul 19, 2009 | 01:07 PM
RS_SS69's Avatar
Before the BBK intake and tbody car with just bolt ons dyno'd 344 hp 360 tq at 5800ft elevation on a 90 degree day.
After the intake and t body went back to the same dyno on a cooler day about 82 degrees dyno'd 312 hp and 330 tq so yes I did go backwards, this was after I had even iced the intake between runs and made 7 pulls since I couldnt believe it. this was the best pull even after a hour cool down.
Now if you got it cheap then by all means use it, and when you go FI then just get some meth on there and that will cool the intake to perform well.
I got my BBK off a guy in Arizona that was FI and he went 10s in 100 degree heat with it so it will work regardless, I just wouldnt use one again on a N/A setup but for FI hell yes its nice. Looks way better than the black plastic. Hope this helps out.
Old Jul 19, 2009 | 01:44 PM
Arc00TA's Avatar
Thanks for answering my question. This is the info I was looking for.
Old Jul 19, 2009 | 02:34 PM
Arc00TA's Avatar
Anyways, I'm putting it on the car right now, I guess since only one guy had experience with it I will go and get it dyno'd this week and see what happens. No offense to RSSS69, not calling you a liar but LS1tech said I couldn't make 400rwhp with a 224 cam either so I'll give it a shot. It takes me 45 minutes at most to swap intakes so its not a big hassle if it doesn't pan out.
Old Jul 19, 2009 | 02:44 PM
TWS's Avatar
TWS
Anyways, I'm putting it on the car right now.
While you have them both off, weigh them. You may put the BBK back in the box.
I doubt it will make any more power than the LS6. It will weigh more. The heat transfer properties are inferior. It's a lose/lose.
Old Jul 19, 2009 | 06:10 PM
RS_SS69's Avatar
No offense taken at all, just giving you an answer that you asked for...anyway let me know if you get better numbers or worse I would be really interested to see how it turns out. I was shocked that I lost power since the BBK was fully ported as far up the runners that it could be. The one thing I did notice was a hell of alot better throttle response than the LS6 with stock t body. As far as 400rwhp with a 224, it is easily acheived you dont need a huge cam to make good power, I have a 228R now and I love it going to put in some 3.73s and get her tuned on the dyno. Im doing an experiment with a egr blocked LS1 intake shooting for 380rwhp which I dont see why it wouldnt.
Post up numbers when you get her dynoed and good luck
Old Jul 19, 2009 | 07:36 PM
Arc00TA's Avatar
I'll let you know the results for sure, I'm going to try to set it up for this week I have to get the car set for 160* thermostat as well. From driving it right now SOTP tells me I gained something, I think you may have over-ported yours for your setup (I know mine is working off of high intake port velocity more than flow numbers). Curiously, my low-rpm surge seems to have gone away too.
Old Jul 19, 2009 | 07:38 PM
RS_SS69's Avatar
Good to hear, awaiting results.
