FAST intake...Worth It?
Old Jul 21, 2009 | 03:51 AM
TransAmcoupe98's Avatar
Default FAST intake...Worth It?
I know most of you guys on here run the FAST 90 or 92 setups with matching TB's. My concern here is my LS6 intake. With my AFR's going on, they will be flowing 32 cfm over the LS6 heads, but the LS6 intake starts to choke off around 275 cfm; With the FAST its around 285 cfm. Do you guys think that it will be worth spending 1200 for a FAST 90mm setup or should I stick with my LS6 intake manifold?
Old Jul 21, 2009 | 06:23 AM
corvet786c's Avatar
I am running ls6 intake with my afr's, good for now but I think i will be purchasing in a few months.
Old Jul 21, 2009 | 07:11 AM
slt200mph's Avatar
If you do not get the FAST intake ported you will be disapointed in the small gain that you make after installing it...
Old Jul 21, 2009 | 08:48 AM
corvet786c's Avatar
So what u are saying is that it is worth more hp to port the fast right?
Old Jul 21, 2009 | 09:11 AM
lovescamaros28's Avatar
What is the CFM of stock un-ported 243/LS6 heads?
Isnt it around 225CFM?
Old Jul 21, 2009 | 09:17 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
It's worth it, especially if you have it ported.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jul 21, 2009 | 09:23 AM
Gatsby's Avatar
When you say ported, is that an objective statement? Meaning, you take it to a guy and say "port this"? Or do you need to give him values to work with like the head specs?
And what are you porting? Just each hole that mates to the head?
Thanks for clearing that up.
Old Jul 21, 2009 | 12:18 PM
chrs1313's Avatar
has anyone actaully seen back to back results of porting vs non porting besides what is done by tony mamo...i have seen just as many peost where people have not gained anyhting after it has been ported vs. stock out of the box...
Old Jul 21, 2009 | 01:11 PM
I've never seen a well ported FAST 90/92 not gain over an out of the box FAST.
__________________
Old Jul 21, 2009 | 09:11 PM
slt200mph's Avatar
Call Tony Mamo @ AFR or Ron @ Vengeance Racing and ask about the difference between ported and non-ported FAST intakes ...
Old Jul 21, 2009 | 09:15 PM
Intercooler2's Avatar
Pics show it is cleaning up the flash in the lower portion... top is untouched. Opened up to the head size maybe? TB opened up... other than that I don't see what else.
Old Jul 21, 2009 | 09:17 PM
Detoxx03's Avatar
It is worth it and your ls6 will choke you engine like Ike did Tina
Old Jul 21, 2009 | 09:25 PM
slt200mph's Avatar
As I said call AFR and talk to Tony Mamo or Mike at Vengeance and ask how much they pick up after they port the intake...then you do one and then get it dynoed after you port it and see how you do compared to the pros that do it for a living ...there is more to it than what you think sir...
Old Jul 21, 2009 | 09:39 PM
True. I'm going to port my own so who knows. I know I did view some pics of one ported by a well known and it wasn't exactly rocket science they performed.
Old Jul 21, 2009 | 09:53 PM
lemons12's Avatar
Caleb, i already told you what i gained when i swapped mine didnt i?
i would do it.. you have the money so why not? even if its 15-20rwhp.. after you sell your intake its only going to be around 800 bucks..
your not going to see a ton difference in the low to mid range, but it will pick the top end a lot.. i picked up almost 6mph with my intake/heads through the 1/8..
BTW, if you are going to get rid of your intake let me know.. i would like to work out a deal with it.
Old Jul 21, 2009 | 09:55 PM
SmokedOutZ28's Avatar
Old Jul 21, 2009 | 10:11 PM
eamador11's Avatar
I agree...you will also gain outstanding throttle response..check out this new offer on FAST92 from TPE:
Ported FAST92 flowed and tested
LS6427's Avatar
The difference in RWHP between just 10 cfm increase is like 15 RWHP in the best or worlds. You'll probably get 10. Is that worth $1,200...thats the question.
If you didn't buy the AFR heads yet. How about doing a ported L92 head/L76 intake combo. Make alot more power than with the AFR/FAST combo. Ported, complete, ready to install L92's that flow 365 cfm cost only $1,500. Ported L76 intake ($700).
Just thinking.
Old Jul 21, 2009 | 10:22 PM
HitmanLS1's Avatar
My buddy swapped from a ls6 to a fast and he said it wasent worth the money
Old Jul 21, 2009 | 10:23 PM
lemons12's Avatar
Just thinking.
yea but if you spin high the fast really shines better than the ls6.. if you dont spin high its no biggie..
