transmission to block bolts Please help
Old Aug 20, 2009 | 05:05 PM
fiano's Avatar
Default transmission to block bolts Please help
are the bolt that bolt the trans to the engine metric ??? i was told there standARD but it stripped a tread with little pressure
Old Aug 20, 2009 | 06:36 PM
blades11b's Avatar
they shoud be metric i dont remember anything on my LS being standard when i did my swap
tals7's Avatar
Smile
they are metric cant remember exact size.
Old Aug 20, 2009 | 06:49 PM
fiano's Avatar
thanks i stripped 3 of them dont know what to do now might have to heli coil them!!
someone told me they where 3/8 -16 x 1 1/2 inch long but there metric!!
Old Aug 20, 2009 | 07:15 PM
bczee's Avatar
I think they are 8mm x 1.25mm x 38mm. All bolt, nut and threads on the GEN III / IV engines are metric.
Old Aug 20, 2009 | 08:01 PM
fiano's Avatar
ok now what will i have to do they are stripped heli coil ?? or tap them out to next size i have no clue ??
Old Aug 21, 2009 | 03:42 AM
Chris@Straightline's Avatar
not sure on the length off the top of my head but they will be a 10mm x 1.50 thread pitch bolt
Old Aug 23, 2009 | 07:13 PM
2001ws6-500hp's Avatar
they are a 13 mm bolt but the threads are the same as a 9/16 s bolt, i pulled my motor last week and when i put it on the engine stand i used the same exact bolts as u use for my old small blocks, screwed them in with my fingers, so i know they fit
Old Aug 24, 2009 | 02:42 PM
S10xGN's Avatar
10mm-1.5 x 35
A 3/8-16 bolt will thread in (loosely) but as the OP found out, they WILL STRIP when any kind of torque load is applied!
Russ
Old Aug 25, 2009 | 09:07 AM
Danno74Z's Avatar
What are the bolt torque settings of the transmission (T56) to the engine block?
I found the BTS of the clutch housing to transmission to be 26lb.ft. but not transmission to engine. Are they the same torque?
Thanks,
Dan
Old Aug 25, 2009 | 12:52 PM
S10xGN's Avatar
Thanks,
Dan
37 ft-lbs...
Russ
