Catch Can & EGR Come Inside!
Old Sep 14, 2009 | 11:25 AM
Spd-Kilz's Avatar
Arrow Catch Can & EGR Come Inside!
Who here is running a catch can, and EGR?
Can you post up pictures and tell me who makes your can?
Thank you!
Old Sep 15, 2009 | 06:37 PM
Spd-Kilz's Avatar
Could someone at least give me some options as far as catch cans / mounting?
Old Sep 15, 2009 | 08:51 PM
Gordo78's Avatar
There was a guy in the appearance section that had a 2 can setup, and the second was mounted to the fender where the TCS was. Just a thought.
Old Sep 15, 2009 | 09:27 PM
Spd-Kilz's Avatar
Thank you. I seem to remember that post. Sounded like a really Japanese name. Sokimota or something?
Old Sep 16, 2009 | 12:09 AM
99Bluz28's Avatar
Lightbulb
Sorry no pictures, I'll take some and post them before Friday evening.
I've got my Catch-Can mounted bellow the passenger side headlight on a frame rail bolt in my Camaro. With the Catch-Can mounted there I cut a hole directly below the can. That way I can drain the can by reaching under the nose of the car without popping the hood. I've had it mounted there for around a year without any problems!
I routed the hose under the factory throttle body (I've removed coolant tubes/assembly), then I looped the hose 90* and went along the radiator and in front of the battery then into the fender and another 90* and straight to the Catch-Can. I used about 10 wire ties total to/from the Catch-Can, and I think I used 8-9 ft. of 3/8" oil/fuel line hose.
http://catchcans.com/can1.html
Old Sep 16, 2009 | 10:51 AM
MjMaro's Avatar
BAM!
https://ls1tech.com/forums/generatio...catch-can.html
Old Sep 20, 2009 | 10:33 AM
Spd-Kilz's Avatar
Thanks for the help!
I was able to find a good spot for mine. I didn't have to drill, and it looks fairly good!
Old Sep 21, 2009 | 05:26 PM
PERFECT Z28's Avatar
^ Same brand of catch can that i have
