Porting Throttlebody?
Old Dec 2, 2003 | 12:55 PM
JDPZ28's Avatar
Default Porting Throttlebody?
anyone have a howto write up on it? I tried to search and came up empty.
Old Dec 2, 2003 | 02:54 PM
onebadz's Avatar
www.ls1info.com I think this is the site. Good Luck
WeS
Old Dec 2, 2003 | 02:56 PM
JDPZ28's Avatar
I don't think that is the site
Old Dec 2, 2003 | 03:52 PM
flyinZ's Avatar
Is there any gain?? Or is it a waste of time..
Old Dec 2, 2003 | 04:55 PM
WS6FirebirdTA00's Avatar
do it, all free mods including porting the throttle body show 10rwhp. i didnt feel much seat of the pants top end difference but pickup improved a whole lot and the responce is great! DO IT
Old Dec 2, 2003 | 11:36 PM
jrp's Avatar
jrp
SN95 Director
http://www.ls1camaro.net/sections.ph...ticle&artid=16
its kinda big but its worth letting it d/l
http://24.162.150.39/downloads/LS1%2...d%20Polish.doc
Old Dec 3, 2003 | 06:33 AM
JDPZ28's Avatar
That's what I was looking for. Thanks!
Old Dec 3, 2003 | 01:53 PM
Turo's Avatar
Originally Posted by jrp
great link, thanks!
Old Dec 3, 2003 | 06:29 PM
Cal's Avatar
Cal
I would also disassemble the TB and remove the front half of the shaft also. At first it will seem like the shaft won't come out, but with a sharp whack from a hammer and a block of wood, it will pop right out. Once out, you can remove the front half of the shaft with a hacksaw, die grinder, or dremel then put it back in.
Old Dec 3, 2003 | 06:38 PM
jimmyblue's Avatar
Moderator
One thing I did, which is a good idea for the not-so-
steady-handed, is to put a few layers of masking tape
around the inside of the throat, covering the seating
circle of the blade by 1/8". Gives the Dremel (or
whatever; I used a die grinder w/ larger drums)
something else to chew on if you get a little careless,
as well as being a guide of sorts.
