What catch can is everyone using?
Old Oct 18, 2009 | 01:35 PM
Super Slow Z's Avatar
Default What catch can is everyone using?
I finished up and put on a ported and polished throttle body I did last weekend and I noticed oil in the intake. I figured now is a good time to put on a catch can and hopefully reduce and/or eliminate my oil consumption, so what brand catch can is everyone using and where did they get it from?
I will be seafoaming the motor probably next weekend before my next oil change and while I was doing that I wanted to pull the intake and give it a good thorough cleaning. How would you recommend I clean out the intake? Thanks guys!
Old Oct 18, 2009 | 01:37 PM
JeaneZ28's Avatar
From what I've read the two best are Saikou Michi and Rev Extreme.
Old Oct 18, 2009 | 03:02 PM
02 z/28's Avatar
rev extreme
Old Oct 18, 2009 | 03:46 PM
99Bluz28's Avatar
You can clean it out the intake with carb. cleaner. You'll also probably want clean out the intake ports on your heads.
PM sent.
Old Oct 18, 2009 | 06:09 PM
PM sent.
Good info, thanks.
Old Oct 18, 2009 | 07:06 PM
Caribe's Avatar
I am going to try this next time instead of seafoam:
https://ls1tech.com/forums/general-m...o-results.html
Old Oct 18, 2009 | 09:08 PM
INMY01TA's Avatar
I use a Catchcans.com can.
Old Nov 22, 2009 | 09:13 PM
bigboykilroy's Avatar
Norris Motorsports Catch Can
http://www.mikenorrismotorsports.com...atch_Cans.html
Old Nov 23, 2009 | 12:55 PM
Soul TKR's Avatar
Originally Posted by bigboykilroy
ummm is it just me... or are those the SAME catchcans...?
Old Nov 23, 2009 | 07:36 PM
99Bluz28's Avatar
Thumbs up
Nope it's not just you, they look exactly the same to me.
Old Nov 23, 2009 | 07:41 PM
shaun's Avatar
i use the mike norris/ws6 store can. does what it should
Old Nov 23, 2009 | 07:53 PM
INMY01TA's Avatar
They do look the same huh..
Old Nov 23, 2009 | 10:37 PM
RA032926's Avatar
i have the saikoumichi dual catch cans on mine
Old Nov 23, 2009 | 11:27 PM
Jeep09's Avatar
do you need one or two
Old Nov 24, 2009 | 01:57 AM
MjMaro's Avatar
I'm running a RevX can, does anyone elses check valve rattling terribly during idle? I'm under the impression that the vacuum would keep it from rattling, but it doesn't.
Old Nov 24, 2009 | 06:35 AM
RA032926's Avatar
the one on the dirty side is the most important one... 2 are usually used if the car sees high rpm's alot of the time, like in road racing... the higher rpm's can force oil vapor through the clean side as well, so that's where the 2nd can comes into play... i doubt i will ever see any oil in my 2nd can since my car is rarely driven but it's there if i ever need it... and the dual can setup from saikoumichi is about the same, sometimes less, in price when compared to most of the others
