Tb porting
Old Oct 24, 2009 | 07:02 AM
SHORTZ A KILLA's Avatar
Default Tb porting
Any suggestions on how & what to use to smooth out the bore? I want to polish the exterior body (blue magic chrome polish) or powdercoat it-its a stock 78mm OEM Thanks to all
Old Oct 24, 2009 | 08:38 AM
ls1curt's Avatar
i used a dremel with the sanding bit to take most of the material out, and then poslished the inside with the rubber wheel on the dremel
Old Oct 24, 2009 | 01:59 PM
got any pics of finished product?
Old Oct 24, 2009 | 02:48 PM
supersick99z's Avatar
http://www.ewurl.com/post/DIY-Portin...ttle-Body.aspx
that should help!
Old Oct 24, 2009 | 02:49 PM
Damian's Avatar
LSX Mechanic
Do not use a dremel. Let someone who does them all the time do one.
Old Oct 24, 2009 | 03:55 PM
redbird555's Avatar
I used a dremel with a grinding stone then wet sanded with finer and finer paper then polished inside looks better than the out on mine lol. Took a couple hours to do with the bump stop mod. I didnt do the metal filler thing as I heard that cracks sometimes.... Overall came out good and response is better but that could be due to the bump stop mod too.
Old Oct 24, 2009 | 04:14 PM
hlaalu's Avatar
i and 99% of everyone else who ports their own tbs use a dremel and it turns out fine.
go to the hardware store and pick up a few of the tips for the dremel, put your throttle body in a vice and take your time with it. it's fun.
Old Oct 24, 2009 | 04:43 PM
Super Slow Z's Avatar
I used a single speed 35,000 rpm Dremel from Wally-World and a few sanding disks. Worked fantasic.
Old Oct 24, 2009 | 08:13 PM
Originally Posted by supersick99z
perfect! thanks
Old Oct 28, 2009 | 10:29 PM
Bo White's Avatar
Were did ya get a stock 78mm TB at?
Old Oct 29, 2009 | 12:03 AM
Damian's Avatar
LSX Mechanic
Bo, we should throw on some camo and go on the hunt for this elusive monster they call, the "STOCK 78mm throttle body".
To those of you who said "I ported mine with a dremel and it turned out fine". I hate to **** in your corn flakes, but there is absolutely positively no way you will do a better job than an experience porter with the correct tools. Not too mention, experienced guys are porting them cheap these days. You can thank ME for some of that.
Old Oct 29, 2009 | 12:53 AM
hlaalu's Avatar
so no one can do anything for themselves these days? it's a $50 throttle body, not a set of heads.
but heck, i'm up for a challenge. send me an "expert" ported stock 78mm throttle body and i will dyno my car with it and then my "home ported" throttle body and we will see just how much better it is. i'll pay for the dyno and for the return shipping of your throttle body.
Old Oct 29, 2009 | 02:01 AM
DCC!!'s Avatar
do it!!!
so we can thank HIM for that
hah jkjk im tired lol
Old Oct 29, 2009 | 03:26 AM
I thought the stock unit was 78mm? what is it then?
Old Oct 29, 2009 | 05:55 AM
redbird555's Avatar
I'll second the dyno move. Damian it's fine you do them for a living, however if someone wants to try it by themselves why not let them try it and maybe even give them some helpful advice on it? It's not like were building missiles and letting some big secret out here... My friend has a professionally ported one, I modeled mine after his and theres no way you could tell the difference without looking on the outside where his is polished.
Dan-
Old Oct 29, 2009 | 05:57 AM
redbird555's Avatar
btw stock throttle body is 75mm
Old Oct 29, 2009 | 06:14 AM
MonmouthCtyLS7's Avatar
I can understand that but its not exactly nuclear physics lol...anybody can really do it.
Old Oct 29, 2009 | 07:16 AM
bene's Avatar
Trunion King
I polished/ported mine w/ a dremel and its bits.
Old Oct 29, 2009 | 08:59 PM
Bo White's Avatar
Ive had to fix alot of TBs back in the day that the owner got ahold of with some rotory tool of some sort and probably Damian as well and he is just trying to save a select few some headache. Besides, not everyone owns a rotory tool of somesort and by the time you went and got everything to do it with you could have had it done by a professional. On another note, I like seeing people give a hand at modding thier own cars and parts- thats part of hot rodding.
Old Oct 29, 2009 | 09:03 PM
Bo White's Avatar
If you and I went on a hunting tour together to do just that I believe we would find Bigfoot, Nessy, snowman and Elvis in a UFO before we would encounter the elusive monster of all....the 78mm
