Meziere electric waterpump, a few questions.
Old Nov 2, 2009 | 04:58 PM
99Bluz28's Avatar
Question Meziere electric waterpump, a few questions.
My new Meziere EWP came with a thermostat installed, do I need to still drill 2 holes in it, and also I'm going to wire mine up with a relay so which fuel pump wire did you tap into trigger the relay to power the EWP?
Thanks!
Old Nov 2, 2009 | 05:35 PM
99Bluz28's Avatar
Okay, I called Meziere I'm good with the thermostat, no holes need to be drilled.
But I still need a more direct answer on where everyone wires the relay trigger to.
Old Nov 2, 2009 | 05:37 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I wired mine like they did at LS1Howto.com - it is triggered by the fuel pump relay. When the fuel pump is running, the water pump is running.
Old Nov 3, 2009 | 06:42 AM
teke184's Avatar
that's funny....i followed the instructions on LS1howto and they had me tapping into the ignition system.
i double and triple checked it...they directed you to the wrong wire. not that its a big deal...allows me to use my fan switch and ignition ON to really cool the car down.
interesting that Mez told you the bypass holes are not needed. they specifically say you ARE supposed to drill them in the instructions. strange.
i drilled them in a 160 stat (cooler than what comes with it)...and my temps still hover around 172-175 in the florida heat.
Old Nov 3, 2009 | 06:01 PM
99Bluz28's Avatar
The guy I talked to said I didn't need to drill the thermostat because it has a bypass.
The directions from Meziere also says nothing about drilling any holes. Is there a bypass possibly built into the pump assembly itself?
I just checked the thermostat in the pump today,and it has NO bypass holes.
No problem, I'll just drill them this next Saturday when I install it.
Old Nov 3, 2009 | 06:07 PM
transamsam98's Avatar
how much did yall pay? street or race style?
Old Nov 3, 2009 | 06:18 PM
99Bluz28's Avatar
Street, got it here: http://www.byunspeed.com/product_inf...oducts_id=4516
Old Nov 3, 2009 | 10:40 PM
paint it black vette's Avatar
got mine from sdpc tech vendor. run a 180 stat and my temps stay at 185 degrees also keeps my trans temps fairly low 190 to 202 and i dont run a aux trans cooler. 3600 stall
Old Nov 3, 2009 | 11:04 PM
Martin HD-28's Avatar
What's the difference between street and race pumps?
Old Nov 3, 2009 | 11:16 PM
squee's Avatar
The race pump has no idler.
Old Nov 3, 2009 | 11:18 PM
Thanks for clearing that up so quick!
Old Nov 3, 2009 | 11:25 PM
99Bluz28's Avatar
The race doesn't have provisions for the heater (in/out) or allow you to run the factory serpentine belt system and is a 35gpm instead of 55gpm , but you can get the race with a HD motor which is 42gph.
Old Nov 4, 2009 | 10:49 AM
99Bluz28's Avatar
Okay , i got an email this morning from Meziere stating:
That pump has an internal bypass. No holes necessary.
Sincerely,
Don Meziere
So no holes needed; I'm good to go!
Old Nov 4, 2009 | 11:43 AM
teke184's Avatar
that must be something new.....i had a paper that specifically told me to drill.
makes sense though...simple upgrade.
oh yeah if you search for it, i put a thread up last year with some tips/tricks for the install.
Old Nov 4, 2009 | 01:21 PM
5.3LJimmy's Avatar
I tapped my relay trigger into one of the wires on the ABS module that was a switched ignition hot. I mounted my relay on the shock tower and that was the closest switched ignition I could find.
Old Nov 5, 2009 | 11:46 PM
Always WS6's Avatar
I ran my wire to the Traction Control fuse in the fuse box. I don't have Traction Control but the fuse is still hot. The pump runs whever the key is on which is nice if you are trying to cool down the motor (just turn the heat on inside the car) and is also very convenient if swapping a cam to refill the cooling system.
Old Nov 9, 2009 | 02:03 AM
99Bluz28's Avatar
Thumbs up
Okay, got her done today! I went and connected my water-pump relay turn-on wire to the gray wire coming out of the fuel pump relay (goes to the fuel pump). And I didn't drill any holes in the thermostat, the temperature looks to be about 185* with the 180 stat, also I flipped the upper hose around for more clearance from the pump.
Thanks for the help!
Old Nov 10, 2009 | 10:42 AM
cutlass_455's Avatar
I always drill one or two small holes in a stat. I dont trust much of anything, and I know that a hole I drill will help with initial purging.
Old Nov 11, 2009 | 09:51 PM
99Bluz28's Avatar
Question
Does anybody know if the Meziere EWP mounts the belt tensioner in a different position than the stock pump? Because I now have my Katech tensioner maxed-out to get the tension up to 35ft.lb. Or has my Gates belt managed to stretch over 2" in less than 2 months and 2k miles?
Also today I installed a Goodyear Gatorback drive belt that's 1" shorter then the gates 78" belt that's to long. Oddly enough the 77" Goodyear belt is to short!
Anybody have a similar problem that they solved?
Old Nov 12, 2009 | 07:15 AM
teke184's Avatar
my tensioner seemed to go in like stock
