TCS removal
Old Dec 15, 2003 | 08:16 AM
Default TCS removal
Has anyone removed their traction control system from under the hood?
Thanks
Sal
Old Dec 17, 2003 | 12:58 PM
smoove1011's Avatar
Good question, I will be doing this soon. I think all you need to do is remove it from the fender well and get a new throttle cable (one for an f-car w/o tcs). Has anyone done this?
Old Dec 17, 2003 | 05:50 PM
Damage Inc.'s Avatar
Sweet Cheeks
I hear this is worth some weight. I'd like to hear more on this if someone can chim in on the process's details.
Old Dec 17, 2003 | 06:44 PM
jimmyblue's Avatar
Moderator
If the servo is gone your ASR OFF light will be on full
time. The cruise control cable also runs through this
pulley cluster. I expect you would want both throttle
and cruise cables off a non-TCS car.
Dunno if removing the TCS "brain" from under the dash
would make the ASR OFF light go away...and lose
another pound.
Old Dec 17, 2003 | 06:50 PM
I don't know if I want Cruise control either?
Old Dec 17, 2003 | 10:29 PM
Sweet Cheeks
Any writeups on this delete? I'd love to see exactly what needs to be done and torn off.
Old Jan 2, 2006 | 12:50 AM
paper doll's Avatar
anyone? im thinking of taking mine out also
Old Jan 2, 2006 | 12:55 AM
Phoenix 5.7's Avatar
is it really worth the hassle? seems like the only benifit would be fewer cables under the hood. our SS is a non ASR and cruise car, and the one cable is very clean lookin.
Old Jan 2, 2006 | 01:15 AM
BULLET99Z28's Avatar
how do you tell if you got traction control, My 99 m6 has no buttons or witches to turn it off, I was powersliding around a curve a while back and some low-trac light came on, but no losss of power or anything.
Old Jan 2, 2006 | 01:39 AM
paper doll's Avatar
i have a button above my ashtray that says "tcs" i think it should be listed in the car's options
Old Jan 2, 2006 | 07:16 AM
2000 TAWS6's Avatar
If you don't have the switch to disbale the TCS, then you don't have TCS.
Old Jan 2, 2006 | 08:39 AM
~JOSHUA's Avatar
I want to remove it just to further de-clutter my engine bay.
I've already relocated the coil packs and did the !wire mod, that tcs junk is really the only eyesore left. TCS
Old Jan 2, 2006 | 09:52 AM
paper doll's Avatar
where did you relocate your coil packs to?just wondering..
Old Jan 2, 2006 | 10:05 AM
he probably used the thunder racing coil relocation kit i have. also, some times the low trac lite will come on even on a non TCS/ASR cars.
Old Jan 2, 2006 | 10:06 AM
99SS'Vert's Avatar
ABS will trigger the low-trac light as well.
Old Jan 2, 2006 | 11:32 AM
~JOSHUA's Avatar
I made my own kit. Under the cowl back by the firewall. Polished brackets, did my own plug wires, much better than the Thunder Racing kit.
4 coils per block, one over each valve cover, no splicing of the harness wires, no drilling, plug and play. I'm going to start making my own kits for sale.
Old Jan 2, 2006 | 11:53 AM
paper doll's Avatar
you make a kit and i'll buy it
Old Jan 2, 2006 | 11:55 AM
~JOSHUA's Avatar
I'll keep in touch.
Old Jan 3, 2006 | 12:21 AM
blue01ta's Avatar
another pound.
Is there any negative effect from removing the TCS "brain"? Does it run anything else? I don't particularly care about the light being on I just want to lighten the car up and don't want something else to shutoff from removing it.
Old Jan 3, 2006 | 04:42 AM
blue01ta's Avatar
https://ls1tech.com/forums/general-maintenance-repairs/336981-lt1-lt4-ls1-ls6-f-body-part-numbers.html
About half way through the 18th post. (part numbers)
LS1 throttle cable (98-99, without TCS) = 12565559
LS1 throttle cable (00-02, without TCS) = 12565560
Write up by ACW. Good info to check out for other stuff too.
