Homemade coil relocation setup?
Old Dec 14, 2009 | 12:57 AM
01SOMZ28's Avatar
Default Homemade coil relocation setup?
I'm not sure if this is the correct section?
But i'm pretty sure some of you guys have relocated your coil packs without buying an expensive kit. If so, how did you do it and what did you use? posting pics would be helpful!
Old Dec 14, 2009 | 07:22 PM
DCC!!'s Avatar
i did it ita really easy actually likw 20 buck in total at lowes
Old Dec 14, 2009 | 07:23 PM
kyles2000z's Avatar
way more than 20 bucks.......gotta buy the wires too!
Old May 25, 2010 | 04:27 AM
Soul TKR's Avatar
splain!
Old May 25, 2010 | 06:52 AM
Magnet's Avatar
For $20 I'm interested....lol
Old May 28, 2010 | 10:57 PM
Magnet's Avatar
bump for more info
Old May 28, 2010 | 11:38 PM
bagged67camaro's Avatar
ive seen them mounted under the radiator support but would be cool mounted low on the firewall or inside
Old May 29, 2010 | 06:27 AM
Jon87transam's Avatar
i've never done it, but i understand you have to buy LT1 wires, maybe the "universal type" where you put on your own ends. the LT1 wires have the correct coil ends to put on LS1 coils. other than that, i think most people put the coils under the cowl, some in the inner fenders. i'm sure more will chime in to give placement ideas. you also may have to lengthen the wire harness to reach the coils. good luck!!!!
Old May 29, 2010 | 07:03 AM
IH8FORD's Avatar
Subscribing like to see some pics too.
Old May 29, 2010 | 07:15 AM
Magnet's Avatar
There are kits that do this easily, but were looking for a way to do it ourselves on the cheap... 99bloncoss on here sells the wires cheap, but the kit is pretty expensive for what it is..
Old May 29, 2010 | 07:35 AM
Magnet's Avatar
99blancoss was actually banned but you can still find his website.. pm if you want the info
Old May 29, 2010 | 03:05 PM
99SSJarhead's Avatar
Wouldn't be too difficult, my coils sit on a single piece bracket already, just unbolt that and relocate it where i'd prefer, then drill two holes and bolt into new area. Cost.. the price of four or so new nuts, washers, and bolts, a metal (or any if bolting to plastic) drill bit, zip ties (or something to group the wires), and new wires that will span the distance.
Under the cowl would probably be the best place, just have to take the plastic piece off around the windshield wipers.
I haven't done this yet, but it'd be the way I'd go about it without having to buy a kit.
Old May 30, 2010 | 08:38 AM
badmfkr's Avatar
Default loseing power
don't you lose power w/ the longer wire?
shorter wire has less resistance so spark event happens quicker.
Old May 30, 2010 | 09:16 AM
Magnet's Avatar
Yea you lose like 15rwhp...
No but really, its an insignificant difference from what I have heard/ seen... if it actually made a difference you wouldn't see the top drag cars around running them..
Old May 30, 2010 | 10:44 AM
Magic Man's Avatar
Years ago before there were any kits someone did the under firewall mod and had a good writeup which worked for me.I don't know if you could search back that far on this site or other LS1 sites or if they even keep stuff that long.Might try a Yahoo search and see what you can find.
Old May 30, 2010 | 01:56 PM
ls1curt's Avatar
any more info on this??
Old May 31, 2010 | 09:07 PM
Boost-box's Avatar
I was forced to relocate mine....but i dont have a camaro lol.
Old Jun 1, 2010 | 12:35 AM
Soul TKR's Avatar
wonder why he got banned?
I'm nosey
Old Jun 1, 2010 | 06:52 AM
Bird-Of-Prey's Avatar
I used some Taylor 10.5mm wires for a Vette and some 5/16" threaded rod and spacers. This is what I came up with. Sorry about bad pic quality.
Old Jun 1, 2010 | 11:44 AM
TORCHD 02 TA's Avatar
