Stock MAF question
Old Dec 22, 2009 | 07:50 AM
px33transam's Avatar
Default Stock MAF question
So I had a bad miss problem and after replacing alll the O2 sensors and converters the dealer finally found out the problem was the MAF. My car is basically stock with a lid and catback so my question is what do I do now just replace it with a stock one or is now a good time to upgrade for future mods? I have read alot of the threads in here but nothin really answered my question...thanks for any help
Old Dec 22, 2009 | 09:08 AM
hitmanws6's Avatar
there is absolutely no need to upgrade the MAF at your level. just get a stocker.
Old Dec 22, 2009 | 11:15 AM
69LT1Bird's Avatar
+1 Stock
Old Dec 22, 2009 | 11:40 AM
02CamaroSSLE's Avatar
stock is more than enough
Old Dec 22, 2009 | 11:45 AM
99Bluz28's Avatar
Stick with the stock MAFS.
Old Dec 22, 2009 | 12:55 PM
Thanks guys...I appreciate your input. Stocker it is
Old Dec 22, 2009 | 10:48 PM
1qwkz's Avatar
yezzir
Old Dec 23, 2009 | 12:54 AM
massillongoat's Avatar
Yeah I'd do the same I have the slp 85mm on mine...I can't tell a difference....worst case buy a stock one and port it...
Old Dec 23, 2009 | 08:47 PM
Hemi2Slo's Avatar
One thing you might want to look at before you buy a new one. I had basically the same problem on my car once and when I discovered it was the MAF I changed it but still had the problem. After a lot of head scratching I discovered that the sensor wire pin on the male plug on the car's wiring harness had gotten bent over time and wasn't getting a good connection. I bent the pin back over and put the original MAF back in and it worked fine. You might want to check that out before spending the money on a new one.
Old Dec 28, 2009 | 05:09 AM
Thanks...I will check that first
