Victor jr + my 408 = ??
Old 12-24-2009, 01:15 PM
wesam's Avatar
Default Victor jr + my 408 = ??
I heard that victor jr intakes will outflow Fast 90 in the top end and since my main reason is road racing (roll racing and i don't care about low end ) and i want to shift my car at 7400 i thought that it will be a good step to up grade because my car is peak at about 6300, and then it has a fast drop in the power curve.
I want to switch my unported Fast 90 to Victor jr or super victor jr with a 4 Barrel TB
I want to know if it will have a noticeable gains with my 408 with my cam 239-242 .651 .615 114+2, i already have SD tune.
Old 12-24-2009, 06:54 PM
wesam's Avatar
Any suggestions will be appreciated
Old 12-25-2009, 02:18 PM
wesam's Avatar
come on guys there should be some body tried this and have some advices
Old 12-26-2009, 01:04 PM
wesam's Avatar
i tried to search with out lock it seems no body switched from Fast 90 to Victor Jr
Old 12-27-2009, 01:30 PM
ducky1's Avatar
Default Vic Jr
I wish someone would answer as I have both ready to put on my road racee car and was wondering which to go about outfitting (throttle body, etc)
Old 12-27-2009, 01:41 PM
SIC LSX's Avatar
the VIC jr dose flow better then a fast but the intake elbow you have to use chokes it down! The power loss is way down low not where u would ever need it and any stall over 3500 would be above that mark. only way its worth it is if you run a aftermarket TB on top of the vic jr like a carb.
Old 12-27-2009, 01:44 PM
bpowell688's Avatar
This is my 408 victor jr and accufab 4bbl
Old 12-27-2009, 01:45 PM
SIC LSX's Avatar
https://ls1tech.com/forums/generatio...fast-92mm.html
https://ls1tech.com/forums/generatio...fast-90-a.html
https://ls1tech.com/forums/dynamomet...-b-change.html
Old 12-27-2009, 01:46 PM
SIC LSX's Avatar
yup if you do vic jr thats the only way to do it!
Old 12-27-2009, 09:28 PM
StreetStalkerZ's Avatar
Put a 4 barrel on top of the Victor Jr. and it will run off from the fast.
Old 12-28-2009, 07:56 AM
ducky1's Avatar
Who makes the best Vic Jr mount throttle body? Is that your MAF just aft of the air filter assembly?
Old 12-28-2009, 08:06 AM
bpowell688's Avatar
I had a accufab, there really all pretty close to one another..
And no MAF its a SD tune...
Old 12-28-2009, 10:06 AM
SIC LSX's Avatar
SD tune is the way to go!
Old 12-30-2009, 04:06 PM
wesam's Avatar
so should i go with victor jr or super victor ?
which is better ?
Old 12-30-2009, 05:07 PM
Nitroused383's Avatar
Super victor
Old 12-30-2009, 05:12 PM
wesam's Avatar
Originally Posted by Nitroused383
Super victor
why ?
Old 12-30-2009, 05:32 PM
The super victor will easily out flow the victor jr just do some searches. It is a little taller than the vic jr but for a bigger cube motor that is going to turn some rpm it is the way to go. Make sure you get a properly specced cam for that intake.
Old 12-31-2009, 09:08 AM
1CAMWNDR's Avatar
+1 for Victor Jr with an Accufab 4 BBL throttle body, and yes you will need a new cam designed to work with a single plane intake (more overlap).
