3.5" or 4"?
Old Dec 25, 2009 | 10:24 PM
Gordo78's Avatar
Default 3.5" or 4"?
Ok i've decided to scrap my 2.5" true dual side exit boom-tube idea. Everytime I see someone with a side exit setup, it seems like they took it off due to bad ground clearance. I've decided to have custom mufflex style setup built, with a custom 3" y, flowmaster merge, and a single magnaflow race muffler with a dump behind the axle. Should outflow my side exit idea by quite a bit, tuck up loads better, and probably run less. It will be much like in this link. My question is should I go with a 4" or 3.5" setup? My car just has full bolt-ons now, but i have plans to go heads/cam in the next few years sometime after I graduate college. I can get a flowmaster merge either 3" to 3.5" or 3" to 4" and theyre the same price so that's not a big deal. I'm thinking the 3.5" is plenty for stock cubes, but it probably won't cost much more for 4". Any thoughts?
Here's the link I saw that gave me the idea...
https://ls1tech.com/forums/generatio...aust-pics.html
Old Dec 26, 2009 | 02:18 PM
Gordo78's Avatar
Bumpity. Any thoughts?
Old Dec 26, 2009 | 04:34 PM
omarrakeen's Avatar
isnt 4" too much?? plus the ground clearance...its kinda confusing tho..
Old Dec 26, 2009 | 04:46 PM
Grifter's Avatar
Haha, I was going to post a link to my exhaust.
3.5" should be plenty even if you up the cudes down the road and if built correctly it should have great ground clearance also. I love my system, still get compliments a lot even from people who have heard it before.
Old Dec 26, 2009 | 05:31 PM
c0ncEpT's Avatar
Go 4 inch for sure.
This is Detroitmuscle's custom exhaust set up. His car uses a stock catback and made something like 408 threw the exhaust and 441 with the 4in cutout open. Plus the ground clearance is amazing.
Stenod Performance did all the exhaust work. I must say they did a damn good job also.
Old Dec 26, 2009 | 08:23 PM
Gordo78's Avatar
Lol definitely love your exhaust. The black looks great.
Originally Posted by c0ncEpT
Go 4 inch for sure.
I plan on running whatever it is all the way back, it will either be 3.5" or 4". That is a nice looking setup though, Stenod did a fine job indeed.
Shouldn't be too much with a y-pipe setup. People do 3" duals all the time on stock cube motors, and they run out good. Ground clearance should be fine if its run down the tunnel next to the driveshaft. That was my main concern with the dual setup I wanted, absolutely no clearance.
I might just see what kind of price difference it is. If its not much more i'll go 4" if they want much more i might just go with 3.5". Main factor is good flow with good ground clearance.
Do you guys think it will be any problem running this though a stock tunnel brace? I'm not sure how much more an aftermarket brace adds for clearance.
Old Dec 27, 2009 | 06:03 PM
Grifter's Avatar
I don't know how much more a 4" pipe will flow than a 3.5" one. I've seen the flow charts several times but never saved them. 4" piping is BIG, the clearance over the axle is going to be very tight. There's a lot of people running big cube motors with a 3" system and a cutout. I don't see why 3.5" wouldn't be enough for almost anything you throw at it and if you have a cutout it would make even more sense. I went with 3.5" because I wanted a bigger exhaust than the norm and I didn't want a true dual system. Clearance is still tight over the axle and it does bang occasionally but it's never scraped over bumps.
Old Dec 28, 2009 | 06:43 AM
teke184's Avatar
can always do 4" back to a cutout..then 3.5" the rest of the way
Old Dec 28, 2009 | 09:00 AM
omarrakeen's Avatar
i really duno but 3.5" should be enough i guess...am goin 3" duals the in this week...gd luck with urs dnt forget to update this
Old Dec 28, 2009 | 01:10 PM
ssfast99's Avatar
Do yourself a favor and do the 4" all the way back. people who have done it will never regret it. Still tucks fine and sounds amazing. And a 4" will outflow most setups available. I gained all across the board going from 3" to 4" while changing rear from 10 bolt to 9". let me know if you needs pictures. Also if someone needs me to explain the flow rates of 4" compared to 3.5" or dual 3" let me know.
Old Dec 28, 2009 | 01:31 PM
teke184's Avatar
i realize there is more to flow than just cross sectional area, fluid dynamics is a bitch...buffer layers etc...but here is the jist...
cross sectional area of tubing (sq inches):
2.75" = 5.94
3" = 7.01 (15% increase over 2.75")
3.5" = 9.62 (27% increase over 3")
4" = 12.57 (44% increase over 3", 23.5% over 3.5")
dual 2.5" = 9.82 (28.5% increase over 3", only 2% over 3.5", still 22% behind 4")
dual 3" = 14.02 (10% over 4")
Old Dec 28, 2009 | 02:29 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I had that 4" setup for a while. You can find pics in the staff showcase from it. I loved it. Had a 3.5" collector and went into a nice magnaflow muffler. Let me check on pictures.
Old Dec 28, 2009 | 02:50 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Here is the link: https://ls1tech.com/forums/staff-veh...peels-99s.html
Old Dec 28, 2009 | 04:34 PM
ssfast99's Avatar
2.75" = 5.94
Very nice info and I commend you on the math lol. But the dual 3" compared to single 4" shows dual 3" flows better and I believe you on your numbers. It's just scavanging effects on air velocity changes things. A 4" will create a cleaner and better flow over the dual 3" causing a greater pull effect on the exhaust. Remember exhaust will flow thru the least restrictive path. So the only less restrictive path over a 4" is a true true dual 3" short tubes with no x or h pipe.
Old Dec 28, 2009 | 05:36 PM
teke184's Avatar
as i stated...its not ALL about the cross sectional area...alot more plays into the equation.
but it does give a means by which to compare...
Old Dec 29, 2009 | 10:31 PM
DemonInside's Avatar
pics def would be sweet
Old Dec 30, 2009 | 12:24 AM
merlinn's Avatar
3.5" setup
Old Dec 30, 2009 | 02:55 AM
Armageddon's Avatar
...with cheese.
4" exhaust is way overkill... It might sound good, but to a point you need backpressure.
Old Dec 30, 2009 | 02:03 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That was why I went to 2.5" duals.
Old Dec 30, 2009 | 03:44 PM
ssfast99's Avatar
Ummmmm no lol. U need scavanging effects on the velocity of the gases. Thats why a good y pipe is a necessaty. after the y pipe it does nt want or need back pressure
