New Mods... Having Problems
Old Dec 25, 2009 | 11:19 PM
Brian'sCharlotte(TA)'s Avatar
Default New Mods... Having Problems
I just installed a Ported LS6 intake as well as a Ported and Polished stock throttle body and I'm having an Idle issue. When I TAP the idle the RPMs will shoot up to about 1500 and hover there for a few seconds befor settling back down to normal. I'm not sure if all the new air is messing with the MAF sensor or if the car just needs to be tuned or what.
Old Dec 25, 2009 | 11:52 PM
mook99ta's Avatar
Check your throttle cable. When I did mine it some how got stuck. If thats the problem take the clip off where they connect back by the rear of the fire wall, let the cable extend and then put the retaining clip back on.
Old Dec 25, 2009 | 11:55 PM
^^^hmm.. good idea
Old Dec 26, 2009 | 01:20 AM
mike135531bubba's Avatar
did you disconnect the battery when you swapped these parts? did you check for a vacuum leak?
Old Dec 26, 2009 | 02:15 AM
Yeah, I had the battery off a couple of times to try and clear the security code that came on for some reason. And as far as I know there were no vacuum leaks. I also deleted the EGR/AIR/and rear O2s if that would make a difference.
Old Dec 26, 2009 | 06:19 AM
mook99ta's Avatar
It shouldn't, does the motor try to fall on it's face when you slowly apply the accelerator? thats a good indication that there's a vacum leak, or you can take some starter fluid and go around the manifold and see if your idle changes at all.
Old Dec 26, 2009 | 09:35 AM
VeTTeMaNC486's Avatar
couldn't it be caused by the ported TB? Like if he or whoever accidentally took some material out around the TB?
Old Dec 26, 2009 | 10:34 AM
removing the egr/air won't have anything to do with it. who did the porting? and what codes are showing up?
Old Dec 28, 2009 | 01:37 AM
mook99ta's Avatar
you also could have opened your blade to far at wot if you did the bump stop mod but if it is an idle issue that's probably not it.
Old Dec 28, 2009 | 09:07 AM
omarrakeen's Avatar
had the same thing before i thot its the cable too i checked it was alright then i disconnected the battery for 5 mins so it resets or something it was alright then i duno if this solved the problem or it was something else lol try again for longer time ...may b it helps
