Updated!! FAST intake fits like SH!T...whats everyone do to fix this???
#45
How do you build an intake to fit every set of heads out there? Some heads are unmilled, milled .030-.040. Not every head has the exact same dimensions as stock, for obvious port flow reasons. Looks like the TFS heads have a little bit of a raiser runner intake. I port matched my fast intake to my 243 heads I had milled .020. They lined up great top and bottom, but side to side some of the ports were up to .060" off.
No one said everything is quick and easy in life. I have over 15 hours alone in porting my fast intake. Make sure you seal your intake back up with a little silicone as the fast intakes have been none to leak internally, causing hp losses. I would smoke test the intake after you are done, these damn plastic things are a pain to seal up.
You should seperate the middle and the bottom piece to radius the entrance to the runners. That and remove the big bulge on the side of the entrance.
#46
thats normal, the floor angles suck. Even look at the design pic from fast, with a stock head shape. but they make power. I havnt seen it with these heads, but the prc terminator heads wer even worst. Stock heads are not that bad, but I still dot like how the floor angles are so diffrent.
don't be worried about epoxy falling out. There no fuel on it, you can drill some little .07 holes in the floor so it bites into that. Fast has a 2 part epoxy they can tell you if you call. That bonds really well, people use it to fix broken TB flanges off with it and its fine. I know some cly. head guys use slashzone, on these to fill the floor up.
#47
#50
What a Load of Crap
We pay alot of money for speed parts and often recieve half *** service and half the **** is engineered poorly or out right Wrong !
You could have a custom intake fabbed up for near the same price
" I'll Pass on Fast "
Buy a Fast And Get passed lol
Bon
Bon
#51
My only gripe about FAST intakes is the price. I worked at an injection molding plant in Frankfort KY that actually makes the L76 Intake manifolds and it doesnt cost them but a few dollars to make those plastic pieces after the tooling is paid for.
The L76 was on a Lost Core procedure part that is injected into a mold with a Bismuth Core and then the Bismuth Core is then melted out using a solution and electrical charge.
The regular 3 piece manifolds that were welded together using friction/vibration method were super simple to mold and even cheaper.
So in a nutshell at 800-1000 dollars they are making bank on the FAST intake manifold!
I want to see someone make a Cathedral port version of the LS7 Intake... they outflow FAST all day long!
