Valve covers? Help!
Old Feb 10, 2010 | 10:38 AM
EATSGTS's Avatar
Default Valve covers? Help!
I recently bought a set of fabricated aluminum valve covers at a swap meet, after I got them home and began comparing them to the stockers I noticed the stock covers have vacuum lines running to them ( from the TB and back of the intake). The new covers dont have ports for this. Will this cause a problem? If so, how can I fix it?
Old Feb 10, 2010 | 11:24 AM
Nasty N8's Avatar
You need to plumb in the motor venting somehow. Motor needs to breath.
Old Feb 10, 2010 | 09:17 PM
EATSGTS's Avatar
Thanks, any detail on what i can do?
Old Feb 10, 2010 | 09:23 PM
Dewman's Avatar
drill/tap/weld for -AN lines and run to a catch can
or run a breather cap on the one valve cover as well as tapping the otherside for a vent
Old Feb 10, 2010 | 10:24 PM
EATSGTS's Avatar
so just make sure their vented? I was thinking about drilling them and putting a fitting in that i can attach the hose to.
Old Feb 11, 2010 | 09:00 AM
1BADTALS1's Avatar
Hmm. let me know what you do. i may have the same problem soon. if i do i was also thinking of just drilling a hole and welding in a fitting for the hose to go to..
i was thinking about doing one where it it thredded so just drill the hole big enough and put a nut on the inside.. but that could go very wrong if it came loose.. weld in would be the safer bet.
Old Feb 11, 2010 | 11:13 AM
EATSGTS's Avatar
Ok. It may be a while before I do it, but I'll take alot of pics. I dont know why they dont put some sort of fitting on it. Thats what I get for being cheap.
Old Feb 11, 2010 | 08:59 PM
1BADTALS1's Avatar
yeah i don't have mine yet but they are ordered. how many lines are there? is it on both covers or just one side?
Old Feb 11, 2010 | 09:58 PM
SweetS10V8's Avatar
If you have a vent anywhere, remove PCV altogether and cap any ports on your intake.
Old Feb 12, 2010 | 10:55 AM
EATSGTS's Avatar
I didn't look at it too hard. I think its one on each side, someone correct me if im wrong.
