Going to do it myself now...(Header Install)
on monday? I will be doing this job probably by myself since everyone else i know has a job
. Any tips will be highly appreciative. Thanks
https://ls1tech.com/forums/showthrea...setter+install
Quick tip
Last bolt for the coil pack on the passenger side, get in there with a wrench, forget the ratchet cause you'll never make it. Don't put that last bolt back on when your putting everything back.
Oh yeah your probably gonna need some help when putting the headers on, its kinda tough holding the headers in place while reaching up and putting the nut in, while holding the gaskets in place.
Quick tip
you dont need to remove the coil packs period, but it helps though. and you dont need to remove the fuel lines at all.
Thanks for all the advice.
Probably ask for more tomorrow or monday. Leave the coil packs on and remove the back bolts and plugs from under the car. once you get the cats off you can easily get to these.
Alan
Alan
http://www.geocities.com/y2k_ta/smr0...erinstall.html
I reused them when I installed my Taylor wires. Personally I think that it is overkill but using a 10.4 mm wire is also overkill. If they fit, why not reuse them.
