LS-6 water crossover ?
99T/A if it matters.
If so, the LS1 Crossover, that fits under the LS1 Intake, needs to be removed and the LS6 blocks are fitted into the rear where the rear of the LS1 lines were bolted. Then the front crossover bolts in where the front of the LS1 lines fit.
You can also retain your LS1 lines (and not need to use the LS6 Crossover & Blocks) under the LS6 Intake by chiseling some of the ribs from the bottom of the LS6 Intake. This will allow for enough room.
TheBlueKnight has a great LS6 Intake Installation Video that includes removal of the ribs if you're interested. Here's the link...
https://ls1tech.com/forums/generatio...old-video.html
The ls1howto.com link in the post above is a great write-up, as well. Good luck, dude.
You can also retain your LS1 lines under the LS6 Intake by chiseling some of the ribs from the bottom of the LS6 Intake. This will allow for enough room.
Yes I do have the kit with the block-offs and crossover tube. (Thanks SPEEDTWEEKERZ) I did see the video but I didn't want to chisel the ribs off the intake. I know it isn't hard to do but I hate doing things when I believe there is a better way. Thanks for the link. I am still getting used to the newer cars. I have been an old school SBC guy for EVER. I really like the LS engines but I am still finding out that I have lots of DUMB, simple questions. Thanks for the help fellas.
Just a note to say good job on your LS-6 intake vid. It was very helpful. Thanx
I can completely understand why guys chisel the ribs to keep this, but you're right it does seem like its not the proper way to do this.
I actually went with my own method. I used two of the Front LS6 Crossovers (one at the front and one at the rear) and plumbed them together with fuel line and a T-fitting and then into the coolant line. This way I wouldn't need to grind the ribs and I could retain coolant flow to the rear cylinders. I've yet to drive the car since completing the install (******' Winter anyways), but it seems to be functioning perfectly the number of times I've started the vehicle.
I hope this helps and if you have anymore questions, feel free to ask.
I actually went with my own method. I used two of the Front LS6 Crossovers (one at the front and one at the rear) and plumbed them together with a T-fitting and then into the coolant line. This way I wouldn't need to grind the ribs and I could retain coolant flow to the rear cylinders. I've yet to drive the car since completing the install (******' Winter anyways), but it seems to be functioning perfectly the number of times I've started the vehicle.
Everywhere I researched told me the LS1 coolant lines will not fit between the LS6 Intake and the LS6 Valley Cover. And with the factory PCV system removed, it gave me the perfect spot to plumb a coolant line from the rear, between where the passenger side head meets the intake. So thats what I did. I even ran the coolant line through the old PVC's foam padding to give a stock appearance.
This is definitely more expensive than either of the other methods because you have to purchase two LS6 Front Crossovers. But I like with the way it turned out, so I'm glad I did it.
That right there. A little more pricey, but still one of the best options. We sell them as well from KUP.
