The New FAST 102MM?
Im pulling the trigger friday on the new 102mm FAST intake and throttle body.
I was wondering if I should get the fast the FAST throttle body or the PTM that TSP offers? other than price whats the difference between the two?
Ok.. If you're really set on it then go ahead. I'd say a 92 would be fine, but that's just me. But then again, if I had the money, I'd go with the 102 as well..
I've read LS2 rails are fine, but it also says LS3 rails work as well.
Depends if he's still pulling vacuum @ WOT.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Texas speed is one, who is a sponsor. There are others as well.
http://texas-speed.com/shop/item.asp?itemid=892
YA but where he is getting at is the sponsor said for an all FAST setup 1290 shipped which is an awesome deal considering the fast tb is 519. And why does texas speed have a 100$ difference on what appears to be the same intake, ls7 and ls3? (102mm setup)
Straight off the website
" The FAST™ LSXR™ 102mm Intake looks massive when compared to the stock intake. How much of a power increase can I expect to get from this thing?
This is a major misunderstanding in our market. Throttle “diameter” has absolutely nothing to do with torque curves or if an engine makes power down low or up high. All it does is dictate how much restriction the intake will see (less is better), and the size is directly proportional to throttle metering. If you open a large diameter throttle 10%, it is equivalent to opening a smaller diameter throttle 15%. To address this, the FAST™ Big Mouth 102mm Throttle Body™ (part #54102) has a convoluted shape to help with low speed drivability. FAST™ only recommends 102mm throttle bodies with “convolute” barrels for proper drivability. "
