Finally done with these headers!!!
Old Feb 23, 2010 | 04:31 AM
  #41
MaxBlown's Avatar
Originally Posted by ss_slowmaro
I used zip ties to hold on the exhaust manifold gaskets to the header to help keep them under control with the install. Once you have 2 bolts in the head just cut the zip ties and continue to put in the rest of the bolts
Now why the hell didn't I think of that!!! Good tip bro!
Old Feb 23, 2010 | 10:03 AM
  #42
usafcrewchief01's Avatar
Everyone seems to complain about installing these and honestly it was not that damn bad. Just get a buddy, a case of beer, some classic rock music, and go to work.. Biggest piece of advice is to have patience and have fun with it. BTW I installed pacesetter longtubes if that makes any difference
Old Feb 23, 2010 | 10:28 AM
  #43
BlueStreak362's Avatar
mine took maybe 3 hours to do on the ground. the ORY fitting was a different story.
Old Feb 23, 2010 | 11:06 AM
  #44
firefighter813x's Avatar
Good idea
Old Feb 23, 2010 | 08:09 PM
  #45
doublea87's Avatar
+1 for patience! i installed these exact headers on my 02 TA at the end of summer. my advise is to take to oil filter off for the drivers side and the starter off for the passenger sid. it helped greatly for me. another thing you might have to do is have a friend jack up the tranny a bit for the pass. side. while you slide it in. air tools work great just dont trap the ratchet between the body and the bolt to were you cant get it out and it strips it threads. ha happend to me. good luck
Old Feb 23, 2010 | 09:01 PM
  #46
mylittlez06's Avatar
wow, why didnt I think of any of this, thanks for the advice guys, im gonna start on it again tomorrow, I wasnt able today cause I had food poisoning and had to go the hospitol.....but ill keep you guys posted on how its coming........and you guys are right, I really hate the number 5 coilpack bracket bolt, thanks for all the help!!
Old Feb 24, 2010 | 02:25 AM
  #47
SSdimension's Avatar
+1 for beer and rock. +2 on patience,
Old Feb 25, 2010 | 07:21 PM
  #48
well, all the header bolts on the driver side came out OK, lets hope the passenger side does the same.......ill probly work on it this weekend......and that ******* last coil pack bolt cut the living **** out of my hand lol
Old Feb 26, 2010 | 07:56 PM
  #49
joecar's Avatar
Snip off the pointy ends of the plastic pins that stick down from the cowl cover.
Old Feb 27, 2010 | 01:50 PM
  #50
it wasnt really those that were cutting my hands, I have ginormous gorilla hands and I have to force them in there to get to anything
Old Feb 28, 2010 | 01:23 PM
  #51
joblo1978's Avatar
Get a chick to help you. Was great watching my wife get elbows deep in the car, she was a big help.
RIP out the AIR while you're in there, ditch the TCS too. That will help alot.
Old Feb 28, 2010 | 02:24 PM
  #52
I like your logic!
Old Feb 28, 2010 | 02:37 PM
  #53
1998Z28LOADED's Avatar
10mm ratcheting wrench & patience FTW!
Old Feb 28, 2010 | 02:43 PM
  #54
heartless_T/A99's Avatar
im also currently installing LT's and the last coil pack bolt on passenger side SUCKS! im also wondering if the passenger manifold comes out from the top or bottom? and one of the middle header bolts is right behind the oil dipstick, how does that bolt come out?
Old Feb 28, 2010 | 02:51 PM
  #55
jeepers_88's Avatar
you have to take the dipstick out
Old Feb 28, 2010 | 02:52 PM
  #56
how does it come out?
Old Feb 28, 2010 | 03:28 PM
  #57
joecar's Avatar
Undo dipstick bolt, pull tube up and out (some fall out, some are stuck).
Both manifolds from the bottom.
Make sure header bolts are the correct length (make sure they will not bottom out in heads).
I like to clean the bolt hole threads with a thread chaser (not a tap).
Old Feb 28, 2010 | 04:49 PM
  #58
grip it down low and wiggle it like a *****
Old Feb 28, 2010 | 05:37 PM
  #59
garygnu's Avatar
do new poly motor mounts raise the engine a create more clearance?I have jet-hots slid right in.the front tires are 1 foot off the ground,the rears are 8' in.off the ground.keep the tranny mount unbolted ,and use a jack with a block of wood on the oil pan to raise a side of the motor up for that last .25 in.
Old Feb 28, 2010 | 05:58 PM
  #60
id like to keep my air, I took it out on my last car thinking it would be alot better without it, but it just sucked and those really hot days
