Finally done with these headers!!!
I'm not sure if you have a copy of the installation instructions for these headers, but I do know SLP provides them with each product on their site. Here is a link to the instructions for these particular headers...
http://www.slponline.com/inst/30052.pdf
I glanced through them and they don't mention anything about having to remove a motor mount bolt in order to install either header.
So, what I would do is, get the motor mount installation completely finished. Which means, have the motor back in place with the long bolts through the mounts and pedestals. And then reinstall the A/C Compressor & Bracket, Alternator, and Starter. Which should put you right back where you began, with the exhaust manifolds and factory Y-pipe off the car, and ready to install the headers.
I have read that some have removed a motor mount bolt and raised the engine to gain space to get their headers into place. I'm sure this would work fine with the factory rubber bushings. But reinstalling the long bolts with Poly mounts can be a bitch without the header in the way. So I can only imagine how difficult it would be with the header in place.
Trust me, finish the motor mount install, and then work on getting your headers on the car.
Good luck, man.
