snapped header bolt
Old Apr 2, 2010 | 03:22 PM
BlurSS's Avatar
Default snapped header bolt
Just wanted to know, how many of you guys have snapped a header bolt on removal or install? What you did to prevent bolts for breaking? I'm about to do a header install and getting kind of scared after removing my Y pipe, any response is welcome.
Old Apr 2, 2010 | 05:35 PM
TheBlueKnight's Avatar
Broke a bolt trying to tighten it to much. Here is the thread...
https://ls1tech.com/forums/generatio...nightmare.html
Old Apr 2, 2010 | 07:29 PM
BlurSS's Avatar
I ordered a set of hedman headers with egr and air, loudmouth muffler, and slp header install kit. I will check the bolts for length before I put the headers on after reading your post.
Old Apr 2, 2010 | 08:19 PM
ls1curt's Avatar
the head was broken off a header bolt on mine, but i was able to get it out with a visegrips
Old Apr 3, 2010 | 12:56 PM
JOSH13's Avatar
I broke one a few days trying to install mine . I'm going to see if it leaks with it in first and worry about it later because I can't get a tool small enough to remove it right now . Good luck use a lot of wd40 .
Old Apr 3, 2010 | 01:11 PM
BlurSS's Avatar
I'm going to soak it with pb blaster over night. Then try to be at the shop by about 9:15 so I can spray it down and let it soak before I get it on the lift.
Old Apr 3, 2010 | 01:15 PM
JOSH13's Avatar
That's a good idea I broke mine on install though so be careful when putting them in .... If any feel wrong going in take them out and start over .
Old Apr 3, 2010 | 02:24 PM
BlurSS's Avatar
thanks guys, lots of good advice, I am alot more confident in doing this swap now. I almost feel like I should have got soild motor mount also, but I will do that when I do a head and cam swap next year.
