3" radiator too thick??
With or without the 160* thermostat the temp never gets below 180* and in order for it to stay at 180* I have to be on the highway going at least 80 (The air has to travel through a 4" intercooler then throug the radiator). and it will slowly heat up as the night goes on. I was thinking about switching it out for a 24x19x2" seeing as it might be easier for the fan to push air through it...what do you guys think?
...just double check to make sure the fan is pulling air and not PUSHING air. when we installed the e-fan on my '68 rs/ss we followed the directions in the kit to the T, but the directions were wrong and we ended up with a backwards flowing fan
and we were completely stumped as to why the bitch kept running hot...till one day i popped the hood with the key still on and i felt hot air rushing through the grille hitting me in the leg. but yeah if thats not your problem then a slightly thinner and wider radiator SHOULD do the trick. in theory anyways.
I haven't even gotten into boost yet. Even with the car parked sitting the temps go up..no matter what I do they go up..even took the thermostat out and it actually got a little hotter. Theres absolutely no room in my car to fit anything else so I can't really move the IC. Only thing I can do is get the thinner radiator and try a bigger fan.
