ive used a autozone reman and have gone threw 3 alts in one week because the crappy remans had a piece of epoxy that would come loose literally after installing them,ive had one come out of the box and fail. im going to upgrade to a brand new one not a reman and that should hopefully fix my problem.
but if a truck one will work ill use that because ive used just the 2 bolts up front on my last motor without any issues
Yeah I have had them last as little as 5 minutes as well..
Big 3? the alt to batt, block ground, fuse box wire????
This is a really good video about the big3. http://www.youtube.com/watch?v=p82xRzCr-lc http://www.knukonceptz.com/ Good site to order good quality wire that is not expensive. I have ordered a lot of stuff from them. I went with their 4 gauge, but I would go with 0 gauge. pm me if the link is gone.
i got some welding wire from tractor supply..to go from the batt to alt....as soon as i get the fuse its going in.....i also did my starter too......also added a new ground from the batt to chassis......unlike that vid......the ground, any ground does not have to be 0 gauge.........while 0 gauge from the batt to alt is nice.........on a stock alt it is really over kill.......a higher amp alt DOES need the bigger wire....that site was great...i have finally found my fuse holder and fuse
If you get that truck alternator soon please update us
Random Question: Does everyone's voltage gauge drop when they first turn their A/C on? Is there anything that I can do to fix this?
I am interested in doing this Big 3.
would i have to run an upgraded battery or is what a shop like autozone has regularly for our cars sufficient? I have an alpine headunit and some aftermarket stock replacement speakers in the stock location.
I think I might have to replace the wire that goes from the back of the alternator to the positive side of the battery. I had a shop do it and they did a really shitty job (zip tied it to the sway bar. I want it to be ran according to the stock routing and it might be too short) so if there is a benefit of doing like a 4 or 0 gauge wire, I am interested in hearing the opinions on that.
Does anyone know the how long each of the three power wires should be, like a pre-measured kind of kit?
Would it hurt to only increase the gauge of the wire that runs from the back of the alternator to the + terminal on the battery?
Would it hurt to do this mod to a car that only has aftermarket stock speakers in the stock location and an alpine head unit?
Would I need an inline fuse like in the video or is that only necessary for people running really loud stereos?
what about this guy mentioning the wire that runs from the fuse block to the + terminal on the battery at about 4:15 into the video? does that wire need to be upgraded as well to turn this into the big 4?
is there anything else that I am missing like a write up or a how to with pictures on someone that has already done this before? Sorry for my noob-ness on the subject. I just kind of stumbled across this, but I am very interested.
Look into power bastards alternators. Their LS1 offering is one of the best out there in the 220amp range. I only run optima batteries in F bodies and always do the big 3. I would never put autozone crap in my car and I strongly suggest you dont either. You will end up paying in the end.
I think you have been given the answer several times. Just stop buying autozone alternators. A new ac delco would be fine if you dont want to spend $300. Chinese alternators are your problem. Get a good one and be done with it.
Hello all,
Im trying to figure out how to wire my alternator. I have a L33 with a MS3 Gold box it has a bosch 160 alternator PN: 15128978. The pig tails has two white wires that are not marked with anything. After reading the thread I really don't want to fry anything. Any help would be great! Thanks!
Hello all,
I would try to help but I have no idea what a MS3 gold box is or a bosch 160 alternator.
