The true cost of a header install. Done right.
What examples can either of you give to support your statements.
I'm not trying to start an arguement, but I've used MSD's on three different cars without a problem.
I'd just like to know why you think they are an inferior product.
And they look good!
Saying they are garbage is just plain stupid, seeing as 80% of the spark plug wire posts recommend MSD wires and have no issues with them.
I'm sure if they were bad, there would be more negative threads, seeing as how many people run them.
And they look good!
Speed Inc also has been using MSD wires exclusively since 99, I imagine theres bound to be bad batches tho.
Anyway, back on topic.
Just last year I installed MSD's while doing my Header Install. I still have the stock plug wires. I don't seem to have any issues with idle or anything else, but maybe I'll have to swap them back in and check them on the SOTP Dyno.
We'll see what happens.
The other sets were all over when it came to resistance per wire.
I can't remember all the names of the plug wires tested.
I remember MSD had just slight less resistance than GM.They were close to each other.
Was this the thread? I remember reading through this before I bought my MSDs....although the place I bought 'em from took too long to ship 'em and a bunch of my stock wires were busted (so no daily driver) so I had to just goto Autozone and get whatever they had. My MSDs are waiting in a box for this summer.
https://ls1tech.com/forums/generatio...y-results.html
Also, this is what other LS1tech users are using:
https://ls1tech.com/forums/generatio...lug-wires.html
-New bolts are not needed
-MSD wires are not needed, GMPP wires are also red and cheaper
-New mounts are not needed and you may get unwanted vibration with prothane
-Why tune out emissions if you have EGR & AIR hooked up?
-The "right way" would include a full dyno tune
Skip the stuff that isn't needed and that will save you $200 as well as the time you will spend swapping motor mounts.
While the Gaskets & Bolts are not needed...is it suggested to do so or do most people just reuse?
I have had the MSD wires and NGK combo for 4 years car runs perfect!!
The Gm gaskets are a must! I blew out 2 pairs of header gaskets before I bought the GM's again.
