My True Dual build
Old May 1, 2010 | 12:03 AM
KurtRardin's Avatar
Veteran: Marine Corps
I don't know if I can wait for the man-money to build up over months. This needs to happen now. I might just have to put some pressure on the wife. How can WE need this?
I found these today: A .030 over 454 Chevelle with some E-cutouts and Warlocks. This is the kind of stuff that empties wallets...
And another with turndowns on them:
Why the hell haven't we used these mufflers before? We've been rockin true duals on F cars for how long? If I'm not the first to put them on a LS1 Fbody, then I'll be the first to document the hell out of it.
Old May 1, 2010 | 09:44 PM
1CAMWNDR's Avatar
I think you'd be better off running the pipes over the axle on the passenger side and hanging each muffler right behind the rear tires.
Old May 2, 2010 | 11:29 AM
KurtRardin's Avatar
Nah, I like an exhaust that dumps under a car. If I had a T/A then I might consider it but I like the way Camaros look when they don't have any exhaust pipes. Not to mention that it would be a nightmare trying to weld that kind of setup at home with the car on jackstands. I've always wanted a dumped exhaust so I think this will be perfect.
Eventually I'd like to make a set of matching turnouts for the cutouts. That would probably look pretty cool.
Old May 2, 2010 | 01:00 PM
AR15 guy's Avatar
Are you just going to run the mufflers under the floor pans before the axle?
Once upon a time I had a 88 Camaro with LT headers, straight to an H pipe to 2 chamber flow masters and turn downs. They are bolted onto the floor board before the axle. It was LOUD, plus clearance was almost non-existent. Eventually one side got violently ripped off when I went up a small hill that had a man hole cover on it.
Old May 2, 2010 | 01:38 PM
KurtRardin's Avatar
Yup that's the plan. It's hard to have true duals on an Fbody without hammering in a few places to get some clearance. There are a lot of guys on here that run a similar setup. The only thing that will make mine unique are the mufflers, but it's not because of their size. People run flowmasters and maganflow mufflers under the car all the time. Only the ones that use a BFH on their rear seat pans get to experience good ground clearance.
Old May 2, 2010 | 03:12 PM
bww3588's Avatar
Originally Posted by MM98
I've got an Edlebrock tubular ta, the pipes were fine, it's the muffler case size that gets close to the lines. Passenger side is no problem, it's the driver side that you gotta get creative with.. I've had mine on for over 3yrs now with no problems, but there isn't a lot of room between the muffler and f-lines. If I get some time I will try and get you some pics to give you an idea.
Actually, now that I think about it, the one chambers flowmasters are a 4x10 case, so you should probably be ok. Good luck with it man and I will still try to get some pics for ya.
how bout some damn sound clips? been waiting for 3 years....
Old May 2, 2010 | 03:21 PM
KurtRardin's Avatar
I got this:
MM98's car With Mac Mufflers, H-Pipe:
http://youtube.com/watch?v=TFe0CZtGLus
http://www.youtube.com/watch?v=11ARHOryPHc
MM98's car with Delta Force race 40 series, case size is 3" x 8" x 8.5":
http://videos.streetfire.net/video/7...320183205a.htm
... and here's a shot of what I'm talking about doing with my floorpans:
Gotta say, MM98, you've definitely insprired me to make a system like this. I hope you don't mind me posting up your pictures/videos.
Old May 2, 2010 | 06:17 PM
AR15 guy's Avatar
He has some really good clearance with that setup. Problem is it will be way way way to loud for a street car IMO, but YMMV.
BTW I like his wheels I have a set of those in 17x9'' on my Formula.
Old May 2, 2010 | 08:32 PM
Mumbles's Avatar
The Warlock Mufflers look awesome! I can't wait to hear them behind an LS1.
I'm not sure I'd be willing to beat on my floorpans (let alone cut them, WOW!) in order to get enough clearance for the exhaust.
Much respect to those of you who are willing, though.
Definitely interested in seeing how this build turns out. Good luck!
Old May 3, 2010 | 10:09 PM
MM98's Avatar
Stop it you're making me blush .. I don't mind at all, especially if you or anyone else likes it enough to want to do it.. I just knew I was never gonna get the sound I wanted running a single exhaust set-up.. I love that old school tingy exhaust sound and if it meant making room on the floor pans then I that's what was gonna be done. Thanks again for the comments and Ill be watching to see what you fab up.
Mike
Old May 4, 2010 | 02:04 PM
99monguse's Avatar
I need a low-buck back door way into some electric cutouts... Screw buying a pair of cutouts. I'd love to figure out a way to make something that would either open under full throttle automatically, or come up with a cheaper way to add an electronic butterfly to it.
I think the mufflers on the new ZO6 are like that, aren't they? When you floor it theres a soloniod ojn the mullers that open them up and they get louder and flow better
Old May 4, 2010 | 03:15 PM
  #32
bww3588's Avatar
there is no solenoid, they arent electric. they are pressure activated. when there is enough pressure in the exhaust i.e. WOT, they open up.
Old May 4, 2010 | 10:31 PM
  #33
KurtRardin's Avatar
I'd love to figure out a way to make that. I mean, when I hit WOT it might as well automatically open up IMO. It would most likely make for a more consistant tune too. I'd get to enjoy the low end grunt/throttle response that comes from a setup with backpressure, but also enjoy strait thru restrictionless areas where the engine is loaded... and nasty sound.
Maybe I can figure out how to fab up a valve on a spring, like the new dynamax muffler.
Old May 5, 2010 | 11:13 AM
  #34
bww3588's Avatar
if you can weld and fab, it wouldnt be hard. you would just have to find out how much pressure is in the exhaust system at whatever RPM/load you want it to open, and find a spring that gives up basically at that pressure. IMO, it would be easier (more expensive) to use an RPM window switch for nitrous, and wire the switched side to a pair of electric cutouts.
Old May 5, 2010 | 05:47 PM
  #35
KurtRardin's Avatar
Here's some pictures of the D port merge kit. I really don't lack much in the way of parts; just some mufflers, connecting pipes, and some misc stuff like hangers, etc. I'm debating weather or not to go ahead with it so that I might acquire a torque arm. I hear there's a little more ground clearance to be had if you've got an aftermarket torque arm.
Here's the kit, with a solo cup for reference:
Here's a close up of the outside of the merge:
And here's about the best shot I could get of the inside with my cell phone cam.
I think this merge will funcion pretty well.
As promised I've got it propped up in my garage by the door so I have to look at it every time I come in or go out.
Old May 7, 2010 | 09:45 AM
  #36
sscamaroburn02's Avatar
I would like to hear sound clip when this is finished and installed. looks like a real clean setup
Old May 7, 2010 | 01:08 PM
  #37
KurtRardin's Avatar
Will do. I'll also get soundclips of the hooker catback with 4" merge for a little contrast too.
Old May 9, 2010 | 10:30 PM
  #38
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That's a really nice looking setup. I may have to steal your idea shortly. I like those mufflers too, but I'm going to stick with my ungodly loud no muffler trend.
Old May 9, 2010 | 10:33 PM
  #39
johnrobbins's Avatar
Electric cutout work great. When they work that is! I've had a few issues with the valve working loose.
Old May 9, 2010 | 11:04 PM
  #40
King Nothing's Avatar
i'm stickin with the true dual sweet thunder trend lol
