Rookie Header install ?'s
Old Jan 10, 2004 | 02:50 PM
T-maxx's Avatar
Default Rookie Header install ?'s
The last ( and only ) time I did a set of headers was on my 1990 Mustang gt about 5 years ago. Our LS1's are a little different I don't have access to a lift. Can full length's be done with jackstands ?
Old Jan 10, 2004 | 03:07 PM
cm02WS6's Avatar
Yes they can. You will need to raise the car up around 18" to do it though. I'm sure others will chime in that have done it on jack stands, but 18" is what I seem to remember right now. Now how to do that safely, I have no idea.
Old Jan 10, 2004 | 04:36 PM
felton316's Avatar
I did mine with a set of Craftsman 3-ton jackstands.
Old Jan 10, 2004 | 04:39 PM
foff667's Avatar
LS1TECH Sponsor
check out my install notes in my sig
Old Jan 10, 2004 | 04:50 PM
T-maxx's Avatar
NICE foff ! I think that I will tackle the install myself. Thanks
Old Jan 10, 2004 | 05:14 PM
Bill Bowling's Avatar
Talking
I just installed SLP LT's/Cats/ORYP over the hoildays. I used four jack stands. It was a job but just take your time and you will be OK. What type of headers do you have to install?
BowlingSS
Old Jan 10, 2004 | 05:30 PM
T-maxx's Avatar
BowlingSS
I'm going all out with the Kooks cat and Y. I might have to swap out the loudmouth from what I've been told. I have a Borla cat back.
Old Jan 10, 2004 | 05:37 PM
foff667's Avatar
LS1TECH Sponsor
i run pacesetters, ORY & borla w/no plates..its loud but ive gotten used to it...LM now im not so sure about that...others have used glasspacks/bullet mufflers in teh place of the resonator so its up to you.
lata
Bill
Old Jan 11, 2004 | 06:22 PM
MSCLCAR's Avatar
I just did PPCs on jack stands. You can check out the pics on my website. I had ~24" of clearance - more is better here. I used 4 6-ton jack stands, and had a ramp under each tire to add stability. Not problem with the ground clearance. The install on the other hand.....not fun. I would recommend disconnecting the steering linkage. It's only 2 bolts, and it has helped everyone that did it. Remove the oil filter too.
http://community.webshots.com/user/wahusker
Old Jan 11, 2004 | 08:17 PM
ShadowLightCSU's Avatar
Jack stands are plenty, I had no issues at all with them.
Old Jan 11, 2004 | 08:35 PM
mcflyz28's Avatar
jackstands on concrete blocks
Old Jan 11, 2004 | 09:05 PM
Turo's Avatar
concrete blocks scare me, im afraid they're going to crumple while im underneath
Old Jan 11, 2004 | 09:41 PM
WS6FirebirdTA00's Avatar
too bad u didnt live in NC cause u could use the pit at my work. easy 4 hours top doin headers this way. with 2 people and running into problem....like a welded pipe we didnt know about lol then had to wait on a sawsall to cut that joker.
Old Jan 12, 2004 | 04:59 PM
T-maxx's Avatar
4 hours in a pit=12 hrs for me in the driveway. Maybe I'll be a puss and have my shop do it.
