ls1 oil changes...
Old Jun 3, 2010 | 04:24 PM
JP's Avatar
JP
I use distilled water and one of those HEPA filters from a vacuum
Old Jun 3, 2010 | 04:28 PM
blackfbird98's Avatar
lmao
Old Jun 3, 2010 | 05:21 PM
venom 13's Avatar
Just went and got some 15w50 Mobil One Synthetic
Old Jun 3, 2010 | 05:29 PM
MM98's Avatar
Switched from Mobile 10w30 to Valvoline VR1 20w50 and have noticeably less valve train noise.
Old Jun 4, 2010 | 11:08 AM
majeskyb's Avatar
Originally Posted by MonmouthCtyLS7
Why do you need a filter wrench, its not like its hard to get to and spin it by hand.
While I change my oil 99% of the time on base at the auto hobby shop, there is that 1% that I'll do it in my driveway. The first time I did, I had already drained the oil before realizing I didn't have a filter wrench, and was trying to remove a Mobil 1 filter. Hands had a little oil on them, and it took me a good 15 minutes lying under the car using my hands to finally get it off. It's not that it was over tight, I just couldn't get a good grip on it. So I use K&N ones just in case, and also because they seem to be built really well. Personal preference, ymmv.
Old Jun 4, 2010 | 12:09 PM
MonmouthCtyLS7's Avatar
Always change in driveway, never needed one...though in that situation it sounds like it would come in handy.
Old Jun 4, 2010 | 01:55 PM
TooLateVTEC's Avatar
Go to harbor freight tools if you have one nearby, and buy one of these.
http://www.harborfreight.com/2-inch-...nch-36778.html
I got mine from a friend, but its the same thing and it works on all types of filters and its THE-****. It really helps when doing my gf's 05 V6 mustang, if youve done one of those than you know what I mean.
Youll thank me afterwards im tellin ya.
Old Jun 5, 2010 | 01:42 PM
blackfang's Avatar
No synthetic here. Regular PYB 5w30 every 4-5k miles and a AC Delco filter.
 Michael S. Palmer
Old Jun 5, 2010 | 05:53 PM
omc8's Avatar
Originally Posted by INMY01TA
I've always used the German Castrol but may switch now to Castrol Edge or Penzoil Platinum soley cause Walley World sells the 5 qt jugs of these cheap. Ohh ya I use the Delco PF 61 filter I believe it is.
I use Valvoline VR-1 for break in,Then German Castrol with a K&N filter #HP-2006 its the long case. 2nd choice for filter would be Mobil 1 .3rd choice Puralator Pure One the gold case has high filtration. Any filter is better than a Fram, there junk,dont use it.Even a cheapo STP is better.
As far as oil I'm sticking with German Castrol til I see tests on Edge or anything else.IMO nothing else comes close.If you don't care what brand of Full Synthetic your running, O'Reilly is running a special right now 5qts of their hose brand Full Synthetic and a Mobil 1 filter for 17.99 .Now thats a good deal.Oh I believe Coastal makes that oil , with a O'Reilly label.
Old Jun 6, 2010 | 12:29 PM
LS-1Z28's Avatar
I like using oil filter end caps for removing stubborn oil filters...
luckily the same end cap works for my silverado and camaro
Old Jun 6, 2010 | 02:20 PM
crainholio's Avatar
Originally Posted by ramairfreak98ss
So what is the best to use?
Mobil-1 15W-50. Royal Purple filter.
I have no idea how you use your car, or what weather conditions you use it in, but that's what I use and it works great for the way I use my car and the weather conditions in which I use it.
Old Jun 7, 2010 | 12:34 AM
  #32
Zmg00camaross's Avatar
50 WEIGHT is to heavy, It does great for driveing oil temps up and not get to critcal parts on time due to crappy pumpabilty. LS motors where built and designed for and recommended a 30 weight oil. If a engine builder builds it loose and recommends a 50 weight that is fine but not a stock bottom end ls motor.
Old Jun 7, 2010 | 07:58 AM
  #33
MTBSully's Avatar
how many quarts does a stock ls1 take with a filter and oil change? 5 quarts correct?
Old Jun 7, 2010 | 08:29 AM
  #34
buddha845's Avatar
I always buy 6 and use 5.5 quarts, RP 5w-30 and a RP filter. Made significantly less valve train noise when i stepped up to the RP, previously ran M1 5w-30 for 2 years and it was amazing how quiet it was under the hood after the switch. Of course this is just 1 case of 10 million but im very pleased with my decision to switch to RP
Old Jun 7, 2010 | 08:30 AM
  #35
FancyFarmSS's Avatar
5.5 qts w/ filter change.
I've always ran Mobil 1 5W-30, and I just switched to a Mobil 1 oil filter on the last change.
My car has always had a lot of valvetrain noise-I wonder what switching to a higher weight would do to help? Don't mean to steal this thread, but I guess it could be oil related Anyone else have trouble with a tapping/rattling sound in the 1500-2500 rpm range under LIGHT load when engine is warmed up (oil is thinner)?
Old Jun 7, 2010 | 08:33 AM
  #36
Guess you were answering part of my question as I was typing it lol
Old Jun 7, 2010 | 08:41 AM
  #37
buddha845's Avatar
yea lol talk about timing. I have 0 complaints about M1 and I used to be one of the people who just accepted the valve train noise as part of owning an LS1, but she whispers under the hood now that its got RP. Its always worth a try you might end up happy as a clam too, I know I was.
Old Jun 22, 2010 | 07:49 PM
  #38
omc8's Avatar
German Castrol is best stuff ,like to see tests on the Edge and Pennzoil new Ultra.
Old Jun 23, 2010 | 09:29 AM
  #39
INMY01TA's Avatar
Yes it is. I've used it for years but am getting tired of paying $7 or so a quart for it at Autozone. Walleyworld has Platinum and Edge in 5 quart jugs for like $20 so I may go that route when my GC stash runs out.
Old Jun 23, 2010 | 09:43 AM
  #40
thunderstruck507's Avatar
Most of the oil analysis I've seen for lsx engines shows German Castrol (Castrol Syntec European formula is what it says on the bottle) and Pennzoil Platinum to be among the best choices.
Pennzoil Platinum is cheap and available at any walmart
I use a full 6 qts in mine
