ls1 oil changes...
Old 02-28-2011, 02:16 AM
  #101
X-ray's Avatar
Where are you guys buying the "German" Castrol? The only place I've seen it is on AutoZone's website, and they want $8 a quart. Does autozone ever run oil/filter specials like advance auto?
Old 02-28-2011, 07:30 PM
  #102
ez money's Avatar
i change my oil around every 1500 - 2000 miles due to having deleted pcv i have the breathers and i use valvoline conventional 10w30 and a ac delco filter and never had any problems..
Old 02-28-2011, 09:44 PM
  #103
Lt1Porsche's Avatar
Im starting not to like synthetics in my engine, I get a lot of valvtrain noise when using it. im going to change it again and use a thicker coventional oil.
Old 02-28-2011, 10:31 PM
  #104
LilJayV10's Avatar
What is funny is most people have the same comments in this thread...
1. Use "such oil and such filter" no complaints.
What do you have this to compare to? The car starts up and doesn't throw a rod so it's good?
2. Don't use such and such....
What information do you have to back this up? I read it on the internet once so it's the truth.
People are like a bunch of lemmings.
Let's see what else....Flowmaster's kill power and comp 918's are junk and you can't make power with small cams and ahh....I'm done.
I am sure there are a few and very few people in this thread that actually do have good info regarding anyone of these but not many.
Don't be a sheep.
Old 04-20-2011, 01:06 AM
  #105
The Scammer Hammer
dr_whigham's Avatar
Sorry guys. LilJayV10 just got back from the Player Haters Ball
Hate, hate, hate.....
Old 04-20-2011, 09:00 AM
  #106
kinglt-1's Avatar
Run the oil that is recommended in your service manual and change it regularly....
Old 04-20-2011, 09:19 AM
  #107
XtremeDime's Avatar
I use cheap walmart 5w30 non-syn and a cheap walmart filter. My oil gets changed every 500-700 miles though.
Old 04-20-2011, 12:28 PM
  #108
LilJayV10's Avatar
LOL. I must have been drunk when I posted that. My apologies.
Old 04-20-2011, 06:55 PM
  #109
That's MISTER MODERATOR
Paul Bell's Avatar
This makes sense.
Old 04-20-2011, 07:23 PM
  #110
IrocZTransAm's Avatar
Yes they do. Every 3 months or so. We go through all the major brands in an order. One Autozone month it is Valvoline, then Castrol then Penzoil and so forth. Usually $27-$29.99 depending on the filter it is being paired with.
Old 04-20-2011, 07:42 PM
  #111
Paul Bell's Avatar
Even Pep Boys has the same sales.
Pep Boys will price-match an Auto Zone sale price and vice-versa.
This past year, Auto Zone had the Castrol sale paired with K&N oil filters.
Old 04-21-2011, 03:34 AM
  #112
The Scammer Hammer
dr_whigham's Avatar
LOL, just giving you a hard time! Couldn't resist....
Old 04-21-2011, 09:23 AM
  #113
02 Camaro SS SLP's Avatar
I use 5W-30 Mobile 1 with a K&N oil filter!!!
Old 04-21-2011, 09:32 AM
  #114
udienow's Avatar
I totally forgot to ever reply back to this... here is my analysis of my Pennzoil Ultra:
Old 04-21-2011, 08:46 PM
  #115
tpcaz's Avatar
I've used Royal Purple 5W-30 based on some independent test results I found doing research online. Some of the oils out there that are main stream didn't really perform as well as one would expect when tested under loads. Synthetics will always be better for reducing friction. Less friction = less wear= less heat. Anytime you can reduce friction and heat in an engine, it will actually result in some HP gains. As far as filters go, I have tried K&N twice, and each time I noticed lower oil presuure readings and weird noises from the engine I never had beforehand. First time it happened I thought it was a fluke, changed filters to one I have used for many, many years (Purolator PureOne) and symptoms went away. Next oil change tried K&N again thinking first one was defective, guess what, it happened again. Can't explain it. Maybe because they filter down to such a low micron level, they are actually putting flow resistance in the system, and just maybe my oil pump dosen't like it. But two out of two times is enough for me to know this combo won't work on my car.
Quick Reply: ls1 oil changes...
