FLP headers and high flow cats. clearance issues.
i was having some problems with it running rich in one bank and the cat actually got so hot it burnt a holke in the carpet.
well after chaning the plugs and 02 sensors i believe that problem is gone.
I have FLP headers and high flow cats and dont have much room between the cat and floorboard on the drivers side.close enough to make the floor boards pretty hot still.
yet on the passenger side there is all kinds of room.
Any suggestions??
what did you guys do on your set ups??
thanks!
Can you have the cats removed & tuned out?
Wasn't there a shield there originally? Hmm, I can't remember, ..., I'll have to go crawl under mine & look now, ...
Can you build a shield if there's not one?
im in sw va and do not have emissions but i do have inspections and would rather leave the cats in place.
i do have the option to run catless but the car is already loud enough as it sits.
im not sure it the shield was removed or if it came like that . im new to camaros and just bought this one last weekend.
there isnt much room at all above the cat to install a shield either.
i cant fit my pinkie in the space between the cat and floorboard.
on the passenger side i can put my whole hand in between and there is defintley a heat shield on that side.
just trying to get some ideas and see what others have done.
i probably wouldnt have thought much about it if i didnt run into the problems i had.
i took it for a 20 miles ride today and there is defintley a noticable amount of heat on the floorboard.
i guess ill pick up some header wrap tomorrow and give that a try.
