Meziere Water Pump?'s
I know the LS1 needs to run at it's operating temp at some point, so my question is am I harming the motor since it doesn't even get anywhere near 190-210 until about 20 mins later?
I have a 98 so my gauges are semi-accurate and I still have the stock fan settings so I'm thinking of going to a 180* for the Meziere.
BTW it's only 62* today, I'm wondering what it would be like with really cold weather.
I've also noticed on the highway the temp is at 160 the entire time which still seems to cold for the engine?
It's also interesting that my fans have never and I mean not even once turned on with the Meziere with the stock fan settings since I put it on back in October.
160*-170* is a real good temp,
any colder and the engine could not properly warmup,
any hotter and you could run in to preignition, or detonation
you mite watch each cyl. temp, and maybe other parts of your engine
your gauge mite read 160, but your real temp could be 210
because with out a t.stat the coolant mite be flowing
to much and not absorb all of the heat from the cyl. walls, or exh. ports
so the coolant is not heating to the right temp and causing your gauge
to read wrong.
im just saying be carefull,i used to run no stat in the summer
and the gauge went down but the temp didnt,
i learnd the hard way.
