ls6 #243 or 5.3 heads
Old May 24, 2010 | 08:54 PM
jrz28's Avatar
Default ls6 #243 or 5.3 heads
I have a 99 Z28 m6 with hooker lt's ,ory, flowmaster exhaust and slp airlid so far.I recently bought a ls6 intake and a cam (218 234 .60x .59x 111+2 lsa) to do a upgrade. Want to find some heads so i can do all at one time. What would be better the ls6 heads or the 5.3 heads? And what is the difference between them?
Old May 25, 2010 | 02:15 PM
King Nothing's Avatar
5.3 give more compression but the LS6 243's flow better and you can bump the compression a bit with a different gasket
Old May 25, 2010 | 05:10 PM
SAPS's Avatar
218/234...that's a BIG split!
Old May 25, 2010 | 05:30 PM
sidewayz28's Avatar
243s will bump your compression up to 10.5:1 if im not mistaken.. with a stock MLS gasket
and yea.. whats the deal on that cam?
Old May 25, 2010 | 06:00 PM
jrz28's Avatar
Thanks. I bought the cam from a guy I know. He had it in his 2002 camaro ss. I know with the cam and bolts on it dynoed 408 hp/396tq.
Old May 25, 2010 | 06:12 PM
sidewayz28's Avatar
thats a decent amount of torque.. i dont think ive ever seen a cam with such'a split
Old May 25, 2010 | 06:54 PM
SOMbitch's Avatar
243's IMO.....
Old May 25, 2010 | 07:07 PM
jrz28's Avatar
I think he said it was a cheaTR cam . I've seen cams with a split like mine in the thunder racing website.
Old May 26, 2010 | 12:21 AM
close to a cheater cam and i'm guessing yours has a high LSA, perfect for supercharger applications
Old May 26, 2010 | 12:29 AM
sidewayz28's Avatar
stock for stock go with the 243s
Old May 26, 2010 | 03:05 AM
SOMbitch's Avatar
For SURE stock for stock as the 243's flow about 30cfm more at .600. Even both ported I think they are a better head.
And the compression bump is not as much as you think because once they open up the 5.3 chamber for the bigger bore 346 they are 63cc and some change. I measured my TSP 5.3's after they came off my motor so this is not heresay.....
Old May 26, 2010 | 03:37 AM
armyboyatc's Avatar
I run the ported 5.3 heads on mine and I DARE a car with LS6 heads to step up. Ha I say this because I have had some work done to mine and I love them. The compression bump helped my car out but it worked good with my combo. LS6 heads are good heads though.
Old May 26, 2010 | 11:52 AM
i'll step up at the end of the year when my planter box is running lol are you running a cam also?
Old May 26, 2010 | 12:26 PM
TooLateVTEC's Avatar
243's no doubt.
Get them milled, ported and some bigger valves and go walk all over army boys car LOL
Old May 26, 2010 | 12:36 PM
sidewayz28's Avatar
ok heres my beef: if you FIND 243s with sodium filled valves why would u swap them out? doesnt a lighter valve train = mo' betta'?
but i agree, i wish i would have gotten my 243s ported but i didnt have the cash at the time.. so their flat out stock
